4.6 update and upgrade sound quality ?
Penarth Blues posted:
David252 posted:
All I can say is no! no! no!
I have an NDS with two 555dr power supplies and have today updated to version 4.6 and after hours of listening have had to go back to version 4.4.
I tried the factory reset but even though it did improve things a bit it was not enough.
What is going on this is not an improvement it sounds hollow the bass is tighter the lower frequencies are passable but the mid-range is missing. To add insult to injury the upper frequencies are not satisfying.
If this is the way the naim sound is going this will be the end of the line for me.
I now can not have the other multiroom features unless i have the new sound. You should separate the functional update from the DSP update.
I am at the other end of the Naim spectrum to you with a Uniti2 but I am getting exactly the same effect - a deeper bass, wider soundstage but a 'hollowed out' midrange. It has gone from having 'PRaT' to just sounding 'HiFi' and uninvolving. The mid-range sounds as if someone is muffling it in comparison to the rest - it almost sounds a bit like 'noise-cancelling' is happening in this region.
Now I know my hearing is not as good as it used to be, and the change may just be showing this up, but I no longer listen to the system loud as it just sounds really uncomfortable - like my ears are straining to find the midrange. Closest I can describe this effect to is that of standing in an anechoic chamber where your ears ramp up the sensitivity to try and hear things. Very disconcerting...
I'd revert back to 4.4 but I can't be bothered with the hassle at the moment - in the meantime the Uniti2 is just being used as a really expensive soundbar for the TV where this effect is less noticeable. I'll revert to 4.4 in the Summer when I have a few spare hours to play with it again unless Naim come up with a solution to the problem in the interim.
I talked to my dealeer yesterday to see what his opinion was but he could not help me as ne did not have an NDS any more. He did say he would ask around his customers to see what they think.
I can not understand that there has not be any kind of response from naim.
I have liked naim for a long time because the music is involving and not HIFI like. So I hope the resulting upgrade on my NDS is no intensional.
I have decided to try the 4.6 again next week.
Someone scrolling through this post for the first time and not reading all 500 posts would get the impression that 4.6 has been a major flop in terms of sound quality. I think the reality is that most people, myself included, are very happy with the update / upgrade but as is usually the case it’s the users with negative experiences that shout loudest. Nothing wrong with that, just the way it is.
Hopefully this does put naim off releasing future DSP updates.  Perhaps a switchable DSP selector would be the safest bet.
I would love to provide feedback to naim via an official online survey.
wrc posted:
Yes but the problem I have is that naim do not mention anything about the DSP in the release notes, they only talk about functionality. It would not be so bad if they had said this will change the sonic character of your player, so you could make an informed decision whether to install it.
wrc posted:
Just reread my post and I noticed a typo.  It should read:
hopefully this does NOT put naim off releasing future DSP updates!
David252 posted:
wrc posted:
I really don't know why you have been disappointed with firmware v4.6. The more music I listen to since the update, the better I think it is.
Hi WRC,  it seems to me the majority of people - me included - are happy with the change that 4.6 (& other past updates) have bought.   An impression might be given that the 'don't like' voters are more than the actual number because some have got into a string of posts & it gives the appearance the 'don't likes' are in the majority.      Question is will the 'don't likes' change their mind over time,  will reinstalling the f/w a 2nd time be enough to change their minds (dare I suggest placebo effect),  is any change from the status quo considered bad by some people as a matter of course,   or are people actually reporting a real dislike.
Mike-B posted:
I think it is great if people are enjoying 4.6, however I assure you that I am reporting real dislike. If my system is representative of this update then I must say that it robs the music of soul and makes the NDS sound like other "HIFI".
I am hoping that this is just a hiccup with my NDS and the firmware update.
ken c posted:
I have been on NDS 4.6 for more than a week now and have had he NDS playing a random selection playlist from my collection of streamed music over the past few days while I worked. This was an attempt to let the music 'wash over me' sort of.
the nastiness that I experienced the first time I updated is definitely gone -- so that's good -- I was able to have long listening sessions without wincing in discomfort.
I can definitely pick up  enhanced clarity -- some additional musical lines in the mix -- and this is very apparent for choral music for example.
the presentation seems more 'animated' - you could say 'brightly lit'. it is definitely very 'impressive' but feels like something new that I have to learn to like and live with long term. Old age? Personal preferences, I guess... I found myself missing what i was used to with 4.4!!!
just as a last check, I will revert to 4.4 again one more time next week --and see what I feel like after that. Unlikely I will bore you with further reports.
I will be playing a lot of vinyl this weekend --- for a break. NAT01 sounds familiarly fab in my office as I work.
enjoy
ken
Ken, I am intrigued rather than bored with this topic, so I appreciate the time and effort you are taking to understand the nature of the difference in SQ between 4.4 and 4.6.
I look forward to your feedback when you revert to 4.4 but hope you don't (re)introduce the negative 4.6 if you finally go back to it! The techies will of course say this is not possible.
Donkeyhaute posted:
Pyrrhon posted:
I guess we need to make some statistics by gear model. On the superuniti alone I think its 100% prefer 4.6 by a large margin. If naim collects some data they can then fix a problem if there is one. 'Midrange missing' does not match what the upgrade did on my system. Naim and focal synergy should be near perfect, there might be a 'bug' in the update with the nds.
Not quite 100%, old chap. Mine went back to 4.4 after 2 weeks. On my system, at least, the 4.6 upgrade provided unwanted amounts of 'hi-fi'. But you're correct in stating that 100% is a large margin.
So you prefered your superuniti before? What are your speakers? Since synergy is so important I think you probably have a bright or analytical speaker wich makes synergy better on 4.4. Just guessing !
I’m struggling with 4.6. I have 552DR/300DR/NDS+552DR/PMC Fact 12s/NACA5. I listen mainly to internet radio jazz and classical along with similar on Tidal.  Most of the time (60+%) 4.6 is better, but the other (30+%) it’s tough to listen to it especially at any volume above 9pm on the dial.
A couple of my favourite stations are now tough to listen to as they have become too bright. Cymbals and other similar sounds have come to dominate the music, while mid-range voices are recessed rather than forward.  Similar experience with some Tidal artists, say roughly 30% of my favourite albums now have this bright sound.
The Fact 12s have minor tone controls and I’ve set the bass and high frequency filters to their lowest settings, so less bass and less bright, but still it can be too much.
I’m trying it for this week to see if it grows on me, but otherwise I’ll revert back to 4.4.  I’ve had no issues under 4.4 and the Fact 12 controls were set flat.  I’ll experiment with speaker positioning as per an earlier post, but the Fact 12s are very forgiving with placement - it takes a lot to upset their sound and imaging.  I hope a future upgrade will find a batter balance.
mf99 posted:
This was another issue I had with 4.6 it was not easy to listen at high volumes. I like my music loud  and it is not possible with 4.6 on my system.
I am still waiting a resonse from naim to indicate whether this sonic change was intentional or not.
Hi David252,  what is your system ??? you have nothing in your profile.     It seems those that don't like 4.6 are mostly NDS & most all NDX'ers like it     My NDX has not changed much w.r.t. acceptable high volume levels - but one mans loud is another mans ear shattering too loud,  my loud rarely goes over 85dB,  excl. dynamic peaks (iPad app SPL).   Interestingly when I first loaded 4.6 I felt the bass was a bit much & moved the speakers further out from the rear wall,  I've since fiddled around & they are back to within a few cm of where they were.
Mike-B posted:
Hi Mike
I have and NDS with two 555 power supplies this goes into a 252/300 and a pair of Sopra 2 speakers. All connected by super lumina cables.
There does seem to be a pattern forming that the majority of 4.6 dislikers seem to have NDS players.
Maybe naim just want to nudge us to by the ND555.
David252 posted:
It sure looks that way,   I've posted before that it looks like some dislikers have been posting a lot more on this issue than have the likers.    I'm wondering what other factors might be at play,  in my case the only negative effect I thought was with too much bass,  but even after moving the speakers out from the rear wall I seemed to get used to the change & now have the speakers back in their original positions.     @DaveBl was running the statistics for like/dislike on the '4.6 Verdict' thread & his last post on 3/5/18 reported NDS users were 75% positive for 4.6.   He was going to run some tests with another forumite,  but I haven't seen any updates.
Mike-B posted:
David252 posted:
It stands to reason that those who perceive a negative change would be more vocal in my view, perhaps I'm one of those.
What's bizarre to me however is that those with older products/4.6 update or newer Uniti products/3.6 update who dislike it seem to have quite night and day sound differences between old/new firmware, and if anything most seem to complain of shouty/shrill/in your face vocals but loss, not excess, of bass and low mid range.
I also think there is almost consensus about better detail in the new 4.6/3.6 firmware versions, but the dissenters feel this is at the expense of warmth and musicality, and that the music is fatiguing on the new firmware rather than enjoyable.
Mike-B posted:
David252 posted:
Ken C was going to visit this weekend, but he’s concluded that the main problem was due to a failed installation, and is now trying to get used to the new sound. I’m visiting Graham this week to hear his NDS with 4.4 & 4.6. I think there had been one new negative post since I last ran the stats, so I guess we are now at around 30/70% bad vs good.
Thanks for feedback Dave,  I'm not entirely convinced about a failed install as in a part install fail,   IME with s/w+f/w updates it either installs 100% or fails 100%;   I've gone back & forth 4.6, 4.4 & over the last years more beta rev than I can remember.  I've tried with & without factory resets,  mostly without,  I've even done a factory reset before uploading new code (& that makes more sense to me).   Apart from sonic variations & intended changes I've never had any hint of an install fail,   that said never say never.
Will be interesting to read how it goes with Graham..
DaveBk posted:
Mike-B posted:
David252 posted:
it was perhaps premature of me to cancel the visit Dave. Yes, I managed to get a 4.6 installation that didn't sound as horrible as first time around -- but after living with 4.6 for a few days --  I found myself tiring of the balance - and wincing as I increased the volume (say >10 o'clock). I also found I was losing interest in music -- and paying more attention to what I felt was etched clarify -- akin to a TV picture with too much contrast.
So i have reverted to 4.4 again. Yes, there is less clarity -- but I am finding it easier to enjoy music with this.
I have not given up though-- but unless some new wisdom emerges -- I am staying on 4.4 for now.
I will follow your report on your visit to Graham's with interest.
enjoy
ken
Wouldn’t the reason why the dislikers of 4.6 are among NDS owners be that the degree of SQ refinement achieved with this player, makes it more difficult for further improvement or simple correction for changes induced by DSP coding modifications only meant for functionality enhancement, than for any other streamer? I am getting concerned of what we may be facing with future updates of the new range.
Will Salisbury offer then multiple and memorized firmware updates for typical and pre-determined listening configurations or even tastes? And what about DSP acoustic correction? 🤓
Chag -
Chag... posted:
Or . . . . preferences are subjective and some like the old sound better than the new sound???
There'a always another time Ken, just let me know if you are ever around the MK region and if convenient you can pop round. Linsday - The Strat (Fender) visited yesterday as we only live 10 miles apart and I'm catching up with Graham on Thursday , so will have a few additional data points in to the mix shortly.
With regard to why the 4.6 doubters are more prevalent with NDS based systems, I think you probably have a point Chag, but I'd express it slightly differently. In the NDS, the attention to mechanical and electrical isolation probably makes it more revealing of upstream changes in the digital section. This coupled with more revealing pre-amps etc. probable makes NDS owners more aware of any subtle change. Why some of us have responded positively and others negatively may just be one to personal taste. It's interesting reading Bert's Munich thread that he mentioned a Westend Electric integrated valve amp as:
 "A nice experience to get this vinyl feeling while listening to digital sources. Warm full sound which easily drove the Gauder speakers"
The pleasant, softer sound of tubes is appealing to many, but it could be argued that this is due to the benign harmonic distortion introduced by valve amplification, and that solid state designs are more 'honest' to the incoming signal. Naim amps focus on rhythmic qualities arguably at the expense of some resolution, but they sound great to me. In the quest for musical enlightenment there are many parameters to balance. Naim think 4.6 sounds better, I and around 70% of other NDS owners agree, but that doesn't make the other 30% wrong.
I think the really interesting question is how Naim should  approach future firmware upgrades. There will be new features expected by their customers base - Tidal, Roon etc. being recent examples. As Simon in Suffolk has eloquently described, the electrical noise created by different firmware executing on the ARM or SPARC chips can have audible impacts that are entirely unconnected to the functional change. A few more instructions executing in a time critical loop will impact current draw and noise... So what should Naim do? Stop all firmware upgrades in case there is an audible impact? Add a health warning - "This upgrade may change your personal appreciation of this product"? Continue to add functionality as demanded by customers and do their very best to make it sound excellent to their own and the beta testers ears? From what I have seen, the ND555 further isolates the computational digital section from the DACs, so hopefully the new products will be less susceptible to these issues.
Dave.
As advised by @BPhotographer earlier in this series of posts, repositioning of my speakers has cured most of the nasty sounds experienced after the upgrade to 4.6.
My speakers are providing a better sound stage, bass notes are better defined, and the mid-range is back.  There are still a few instances where the high frequencies are too dominant, but they are much reduced from the initial “not-much-fun” listening state.
Listening at volume levels of 9 o’clock or louder is still occasionally, brighter than I would like, but it’s  much improved now.  It mainly occurs with one of my favourite radio stations - The Jazz Groove.  So, I guess I have to find a new favourite!
I’ll now be keeping the 4.6 upgrade.
I was disappointed on first install.
Ran the install again, performed the reset and very happy now. Bass good(if slightly more controlled-less boom), midrange much better, top end smooth without any aggression(quality of recordings drpendable).
Put the naca5 back(used TQ black ll for 6 months) and the whole thing sounds nicely integrated.
Happy 4.6 here.
From what I remember.....tiring listen, too revealing, less bass, a bit too much top end. Perhaps the sudden change made me think negative and I've just got used to it. Who knows.
I'm pretty sure though thst it sounded better next time round... on a NDX that is.
Pyrrhon posted:
Donkeyhaute posted:
Pyrrhon posted:
Hello, Pyrrhon.
Yes, as stated, I preferred the entirety of my system before the 4.6 update. Possibly because I'd already tuned aspects of 4.6 into the sound via equipment choices (CB NAP 250, WitchHat IC, Tellurium Q cabling , Powerlines, various kinky ferrite clamps, a tasteful antimacassar to deter suitors, scented dice, Lynx Swindon, etc before a species of 'double dosing' was applied via 4.6.
Again, to me, this sounds like a vector towards a more 'hi-fi' sound and drained all the lovely midrange from my kit whilst also privileging the bass and doing odd, unecesarily twiddly, things to the upper ranges.
My equipment's details are visible on my biography page.
I wouldn't say, at all, that my speakers were overly bright. If anything, the opposite applies.
In a sense, I'd already tuned out, over the years,  various bits of the SU and the NAP 250 and my speakers, and now a secondary tuning arrived via FW update and put everything out of kilter. I appreciate that my experience is in the minority and remain grateful to the beta testers, and Naim, for working to improve their kit. And of course that I could return to 4.4
As any body following this topic would know I tried and did nor like 4.6. Over the last few days ai have tried the update again on several occasions. What I found was worrying!
Every time I reinstalled 4.6 the result was something different. The sound changed every time.
I have tried it 3 times now and every time the sound of my NDS changed and it does not seem to be consistant.
When I go back to 4.4 it does seem consistant.
I do not understand what I am doing wrong.
David252 posted:
Somewhat similar experience here. 3rd install of 4.6 -  although it issued an error -- resulted in quite different SQ, which at low volume wasn't as nasty as before -- so I thought I was getting somewhere till I wicked the volume up over the weekend for what I thought was going to be a chance to enjoy 4.6s  SQ enhancements. Oh dear...!  Hard etched sound. Female voices sounding 'saturated' etc etc...
Before the weekend was over I reverted to 4.4. and musical sanity has been restored (just as well 4.4 is available to us!!!)
I so wanted 4.6 to work on my NDS but unless some new wisdom pops up -- I'm close to giving up now...
enjoy
ken
ken c posted:
David252 posted:
enjoy
ken
Ken
Can you remember the error message that you got.
On mine the pc reported success but then the NDS rebooted and gave an err 61. I switched the machine off and on and it recovered ok.
The sound is different and better than the previous times, that did not take much. I have left it to try and see if my son and I can live with it. I have not told my son so I am waiting to see what he think tonight.
@David252, the error message was:
Unable to execute file:
c:\program files\Naim\Streamer Updater\UnitiUpgrader.exe
CreateProcess failed: code 740
The requested operation requires elevation.
No idea what this means or what I can do about it, if anything...
enjoy
ken
ken c posted:
enjoy
ken
It seems to me like you dont have the minimum required version! maybe 4.6 needs at leats version X to be able to run.
Please note: the streaming product must already be on version 3.00 before updating.
Pyrrhon posted:
I don't believe that's correct as I was updating from version 4.4 (which I have been on since it was released quite some time ago and which has been working beautifully)
enjoy
ken
Add Reply
Likes (2)
KlydeMinh Nguyen
