Moving Magnet phono stage for NAC 42.5
Hi, I just took ownership of a NAC42.5 with no phono cards installed. Using it with a NAP 140/SNAPS and an Ariston RD11/SME 3009/Goldring 1012 GX
Looks like the original 322 MM cards are nigh on impossible to get hold of these days (unless anyone can suggest a likely supplier) so I am looking for an external phono stage ...can anyone suggest what would be a good match in line with rest of the system? Looking to pay less than £250 - I dont mind second hand obviously!
All suggestions appreciated.
thanks.
Original Post
Stephen, there are usually some NA322 boards out there - check around some of the usual Naim dealers who specialise in secondhand kit, otherwise a quick online search in the usual places and you should come up trumps fairly quickly. Look for the latest you can - NA322/4 were the last series.
