Naim Unitiqute 2 VS Uniti Atom?
I was just about to pick up a new Unitiqute 2 when lowen behold the new Uniti line was released. Now I find that I can get a mint UQ2 for HALF the price of the Uniti Atom.  I'm debating if its really worth the extra $ for the latest and greatest. You option will help me decide.
This is for music in our kitchen with linn Tukan speakers mounted near our ceiling.
Yes the design of the atom is cool and the led is great but don't really care since this kit goes inside a cabinet hidden from view.
i don't need apple air or goggle cast, only need UPnP funtionality with a ethernet connection.
Yes, I imagine the Atom has an improved dac but the UQ2 has a great dac.
i can buy two UQ2's for the price of an Atom.
Review of UQ2 have been favorable. Do you think the Atom will sound MUCH better or is this a case of only some sonic improvements but mostly design and greater functionality/feature set.
thanks
Original Post
blownaway posted:
thanks
So why are you still thinking about it? You don't need the new features of the Atom, you won't be able to look at it, or be able to reach/use the snazzy control dial and you will be able to listen to DAB radio, FM even, if you want to.
Unless you are possessed of superman's hearing, and spend an awful lot of money on speakers, they'll sound virtually identical.
So, go on, make a sensible hifi purchase that I can assure you you'll enjoy every minute of !
KR, J
Dr_J posted:
blownaway posted:
thanks
KR, J
What would this forum be without a bit of wild conjecture!
Great input everyone! Thanks for confirming my inclination to go with a minty UQ2. At $1,400 USD, I'm all in.  In addition to UPnP I plan on listening to radio via the built-in tuner or internet radio.
The real amazing thing is my WIFE is open to using this purchase as this years Christmas present to each other
Oh, I just realized my Tukan's are hooked up to my Linn Majik via Linn's K400 bi-wire speaker cable.  I would LOVE to avoid re-cabling since it involves  fishing around in our attic, but possible if required.
Can I use my line bi-wire cable with the UQ2 or will it need to be replaced?  The Tukans can be hooked up with single or bi-wired.
Can I use an adaptor from bi-wire to single spade or is that just wrong?
thanks
Pretty sure the UQ2 only has one set of speaker outputs. I still don't see why you can't use 2 of the 4 bi wires on each channel to hook up to the Tukans. Just be sure to be consistent with the wires you use at each end. I assume there is some kind of coding of the wires (multi colour?).
While the UQ2 undoubtedly is great value, I don't think one should underestimate the Atom. It has more power, will handle a wider range of speakers, and I don't have any doubt that it will sound better, even if subtly so.
Also, for those who want to use USB Naim is promising greater usability. Sad to see fm go agreed.
Hungryhalibut posted:
I've just been listening to an Atom and it's just brilliant - miles better than I recall the Qute being. It's capable of massive volume with complete control and sounds lovely, far better than I was expecting. The build quality is fantastic.
Great news
where did you manage to listen to it?
I was having second thoughts vs uq2 but your statement re assure me
ref build quality, the unit seems solid but plasticky at the front from pictures. You didn't feel that in your demo ?
What speaker you heard it with please and if possible cables ?
It doesn't look plasticky at all, just very classy and solid. Somehow the screen is bonded into the front panel which I think is some sort of resin type material. Anyway, it looks lovely with its brushed top and volume knob with integrated Bluetooth receiver. And it has a motion detector too, so the buttons light up when you go to touch them. Overall it looks massively more classy than the Qute: I was really most impressed.
As to the speakers, it was used with Sopra 1s, which wasn't the original idea but a previous customer had asked to hear them so I just stuck with them.
And before anyone asks what I thought of the speakers - very large and very bright. But then the Atom is not what you'd expect to use with a £6,000 speaker. I played White Stripes at over 60 on the dial and the little Atom showed no sign of strain. It really is a serious bit of kit. It makes me interested to hear the Nova if the Atom is this good.
Very interesting HH, thanks for the added info. It certainly bodes well that the Atom didn't embarrass itself driving the Sopra1 speakers. Impressive.
I'm now even more eager to compare my Qute2 with the Atom.
Oh dear - that rattling noise you can hear is my credit card quivering in fear!
Thank HH, you got me super excited. I had some doubts but you took most of them. I will have to check for myself but your feedback is aligned with other feedbacks I read or heard.
the Atom seems to be even better than the qute2 which for me is naim masterpiece (dangerous statement to make I know :-).
the atom seems to be a qute2 on hormones. A bit more power, improved power line, improved connectivity and streaming plus hdmi...
I have also considered the star thinking I may need the extra power for my kef ls50 but I dismissed it  like I did in the past with uniti2. Not sure I need an attached cd transport or a core at all but have the option to add the latter in the future
thanks mate again, can't wait now...where did you see it? Very hard to find
just need help for budget cable speaker...I am thinking chord Clearway at £8 per metre or tellurium q ultra blue or black...potentially a cheaper cable?
advice welcome
Do you think this atom is powerful enough to fill a room of 36 m2  (with  PMC twenty5.23)
It's not something I'd suggest -when I had twenty23s I used a Superuniti, which is a far better match.
Thr Atom is good but that doesn't mean  that common sense in system building goes out the window. You don't use a £3,000 speaker on the end of a £1,750 all in one.
You are most probably right but Atom did well with £6k focal speakers. Some rules apply indeed but depend on speakers sensitivity.
can you please advise what speaker cable you use. Considering tellurium black or ultra blue. Chord clearway potentially.
I have to test myself but interested to know what people use (outside naim own speaker cable)
thanks in advance
I really have not been drawn to the design of the new Uniti's - I find it difficult to disassociate the new units with the more mass produced Muso which I have just not been impressed with, but that's just me. I think that the older units ( aligned with with other Naim ranges such as the Classic) are a great piece of timeless industrial design and for the difference in price it seems like a no-brained to go fo the UQ2.
Crabby posted:
thanks in advance
I use SuperLumina.
Poggy posted:
Based on value for money, you are right as long as the qute2 price  is closer to £1k than latest list price (bundle offer or discount)
design, I prefer the classic design
however the Atom features and future proof new architecture is more appealing to me. Naim made a huge leap and that's good news. Things moving fast and previous generation wasn't flexible enough anymore.
I just need the Atom to replicate what the qute2 did well and add some extras on top. I can live with the design which I hope is better in the flesh if I trust initial feedbacks.
Phil, any news when in December they start to hit shops ?
Crabby posted:
thanks in advance
I use SuperLumina.
Too expensive for me.
Any other good options a bit cheaper?
Good we all
b_lund posted:
I've just been listening to an Atom and it's just brilliant - miles better than I recall the Qute being. It's capable of massive volume with complete control and sounds lovely,,....
So your yelling out an opinion based on speakers you never heard or like
Crabby posted:
Crabby posted:
thanks in advance
I use SuperLumina.
Good we all
Get some cable talk, linn k20, or Naim a4 or a5
Maybe some chord rumour or odyssey
b_lund posted:
b_lund posted:
Don't think anything wrong with that
from what I see, he has more than enough exposure to hifi and he is certainly not a rookie
even if he didn't listen to the  speakers (which happen to be expensive high end) , someone with experience can recognise a good amp when he hears it
i am not a fan boy (yet :-) but find that encouraging
just annoyed that we don't have more feedback...patience patience
Agree with your sentiment there Crabby - Patience required! I have to agree that I’m in that same camp as I’m very eager to hear and also compare the Atom to the ‘Qute2 (and explore the new app), but it looks increasingly like I won’t get chance now until the New Year. Hey ho
b_lund posted:
b_lund posted:
I thought you'd got over slagging off everything I write, but it seems not. If you had actually read my whole post before selectively quoting parts of it you will have read that when I heard the Atom it was used with the Sopra 1. So I don't understand how you can suggest that I have never heard the speakers. Nor have I ever said that I don't like them. It would be impossible to assess their true capabilities on the end of an Atom. But hearing the Atom with very good speakers was enough for me to assess its abilities.
And I'm not going to use a stupid smiley face, even though it's your post rather than mine that deserves one.
I'm not slagging something or everything, that would be impossible as you seem to be living 24/7 on forum, your choice, your need, your behavior
I did however read somewhere, in your endless promotion of your own gear, that you disliked Focal speakers hence I thought it quite stupid to make that firm statement with no real reservations.
Never mind, its really not that important, don't look at it as slagging
Well, Christmas came early for our home.  Our Christmas gift to each other arrived several weeks ago & finally our new (used) UQ2 was installed in our Kitchen last week.  My wife & I are enjoying this so much.  With all of our holiday cooking, it couldn't have come at a better time.  Set up beautifully with our existing UPnP server.  It's so nice to have the convenience of choosing music on the fly on our iPad or phone.  This kit sounds really nice with the Linn Tukans. To my ears better than the Linn MimikII, MajikI & Rega Radio we've enjoyed for many years.  Sounds punchier, a bit more dynamic.  No loss in performance, 24 bit playback, 1 box vs 3 boxes, reasonable cost, easy decision.
Having listened to first, the Atom, followed by the Uniti Star, then the Nova, with (I think) the same speakers - good though the Atom is, when you hear the comparison, particularly the jump from Star to Nova, you will be astonished!
tonym posted:
Interesting. The Atom is supposed to be good. You are saying bigger brothers much better
they have to be I guess but will appreciate what was the biggest difference for you especially Aton to star.thanks
I agree with Tony, the Atom was initially quite impressive - particularly in the more cosmetic areas such as top/bottom/mid, and ability to project a room filling sound with plenty of detail to the fore.  Taking into account the speakers hanging off the end of it, giving it nowhere to hide, this was more than I expected. However, by contrast the Nova really showed what more money, and hence a more capable unit brings, particularly in making sense of the music, with everyone/everything suddenly playing together rather than drawing attention to disparate parts of the recording mix.
Thank you both, thats encouraging
the nova has to be special for that price and considering the competition at that level
If the atom replicate and improve on what the qute2 did then I will be very happy for the price.
I had a brief hesitation with the star but Atom is all I need.
I'm also waiting for the Atom very impatiently. Sold my unitiQute (V1) a few weeks ago, and have a buyer for the NAP100. Put an order in for the Atom and was hoping to have it for the Christmas holidays, but unfortunately, (or perhaps fortunately) Naim is taking their time to get the new Uniti units out the door.
I had a quick listen to the Atom at the hi-fi show in Hammersmith a few months back, and I have no doubts that this is going to be a good upgrade from the Qute/NAP100 combo.
But the wait is killing me....
Likes (1)
bluelines
