Roon and Audirvana or Hqplayer
folks,
some of you are using roon as their frontend - do you have hqplayer or audirvana integrated with roon?
comparing roon native with audirvana i prefer audirvana by miles...
so is hqplayer on same level?
thanks
ralf
Ralf
Original Post
I was switching back and forth between Roon with HQPlayer and Audirvana before - I did not prefer one over another (try different settings, DSD etc.), liking them both a lot. Of course this all changed when I purchased the microRendu and use Roon/HQPlayer which sounds better than anything I have heard before in my setup.
Likes (0)
