'Signal Ground' for 152XS connection
Hi guys,
In the manual for Nait XS, Section 22.8, it states that "A signal ground connections is fitted to the NAIT XS rear panel. This is intended to be used to connect a turntable pick-up arm signal earth only.
I am using 152XS and it is not stated and showed how is the connection. My TT only connect the pick-arm signal earth to its phonostage & it stop there. Do I need to do another connection to 152XS from the phonostage?
Cheers..
Naim CD5XS, Flatcap XS, NAC 282, NAP155 XS, NAP200, SNAXO 242, 2 X HCDR, NACA5, Naim Allae Cherry
Linn LP12 Cherry, Radikal, Kore, Linn Ittok LVII Black, Skale, Krystal, Stageline
Original Post
Christ,
Fyi, I am using Pro-Ject phonostage and RCA link to pre-amp. There are 3 wires from the TT. It's Left, Right Channel and a ground signal from the TT. The ground signal connects to the phonostage ground link.
Since the phonostage only using 2-pin power plug & I am using RCA L/R to pre-amp. I do not know when the 'signal ground' connection from 152XS is effectively to be used? Naim manual does not mention & show a diagram about this connection especially on 152XS in this regards.
achique99 wrote:
"Christ"
Something of an elvevation
Then achique99 wrote:
"Fyi, I am using Pro-Ject phonostage and RCA link to pre-amp. There are 3 wires from the TT. It's Left, Right Channel and a ground signal from the TT. The ground signal connects to the phonostage ground link.
Since the phonostage only using 2-pin power plug & I am using RCA L/R to pre-amp. I do not know when the 'signal ground' connection from 152XS is effectively to be used? Naim manual does not mention & show a diagram about this connection especially on 152XS in this regards."
Ah, sorry, I've done my best, I'm not a miracle worker y'know!
Chris
Originally Posted by Christopher_M:
achique99 wrote:
"Christ"
Chris
Opps...
Perhaps stageline earth is already connected to amp via DIN-DIN cable (That's why I am thinking to get a stageline instead). How does it sound?
Originally Posted by Jono 13:
If you connect the earth from your TT to the phono stage that should be sufficient.
This works for me with a Pro-ject stage and a 152XS.
Jono
Well I will try that then, thanks Jono.
Ha achique99, you spelt my name wrong, then I made a spelling mistake in my response.
You ask about the Stageline. I'm very pleased with mine in the context of my naim system. It just sounds right. Before that I had a Trichord Dino which seemed bright and with an over emphasis on detail compared with stageline, it didn't flow in the same way. The stageline sounds warm and natural to me, in a way quite valve-like but with naim drive too.
There are other good stages out there too: People speak highly of the Dynavector p75, Graham Slee, Lehman (sp?) Black Cube and Rega fono etc. But the stageline provides the obvious synergy with Naim.
Chris
Likes (0)
