Naim Uniti/Qute Programmability (UPnP)
Posted by: Tim Hastings on 19 October 2011
Hello everybody,
Are there any resources that detail the UPnP Device Categories implemented in the Uniti and/or Qute?
http://upnp.org/sdcps-and-cert...ion/standards/sdcps/
I have also read on other R&D related posts about a "NetAPI" which I understand is limited to integration partners. Would it be possible to get access to the SDK or perhaps visibility? (I would be happy to sign any NDA's required)
Thanks in advance,
Tim Hastings
Hello Tim
I am also looking for an API to control the Uniti via ethernet.
The only documents I found, are the RC5 codes and the RS232 API.
I thought about to do a little bit reverse engineering with n-stream and a ethernet sniffer, but the problem is that I have no i-device for n-stream and the time.
If you find some informations, please let me know.
Stephan
I too have been thinking about this. For Naim, open sourcing n-Stream for iOS would provide us all with a great starting point to create some really amazing apps to be able to control our Naim devices. One would hope that Naim see thier role as creating amazing sounding audio equipment - I would be fine if they left n-Stream/iOS app to the community and stopped it's development (maybe it has already stopped).
In the mean time maybe we should set up a git hub repository to be able to publish any information and control codes we can find?
Thanks,
Andy.
Yep. Linn have got some great control points developed. Come on Naim ![]()
Although if the latest n-Stream realease it good then i'll shutup.
James
Looks like a pretty good starting point: http://code.google.com/p/upnpx/
No idea if it supports UPNP media renderer (which I assume is what the Qute uses?).
Amen to that.
Even if the "imminent" n-Stream release delivers us a bug free control point, there's still going to be dozens of features and tweaks missing.
So why not let the community help and create something that Naim's software/UI-department seems to be struggling with? Maybe the possibility of accidentally producing server side features that put UnitiServe to shame is a big turnoff...
Have you seen Thomas' Qute Control project?: http://freeridecoding.com/qutecontrol/
He is currently undecided whether to proceed with this as a commercial venture.
It may be possible to ask him to release all or some of what he has avhieved so far for open source development?
That sounds very interesting.
I have sent an email to Thomas asking for the ethernet protocol.
I will share the answer here.
Stephan
Hello together
This is the information from Thomas:
Hi!
I started out using a simple network sniffing tool to reverse engineer the protocol which
was not very difficult. So that is one option. Since I wanted everybody to be happy,
I also contacted NAIM to approve me releasing a software like this.
They were ok with it and also very helpful and shared additional information -
which is under confidentiality however.
I would recommend to contact them directly.
Cheers Thomas
It is frustrating that I can't use nStream without spending £170 on a Apple device (which would only be used as a Naim remote control) and developing supporting software is so tricky. The upnp support *should* be enough to allow 3rd-party support but it doesn't support volume control or input selection. If Naim could expose that functionality via upnp then the NetAPI being secret wouldn't be an issue.
Go for it chaps ......
I've been waiting for a uniti remote via http since purchasing it a couple of years ago. I'm no software developer but it can't be that hard for Naim or a 3rd party to produce. I'd be happy with having just the uniti screen replicated on my laptop, with full control. Anyway, I'll certainly support any offering that comes out.
@Redmires
Which OS do you use?
I will try to have a look at the network protocol.
Maybe I can do that for Windows.
Have you tried the Upnp Developer tools available here:
These allow some control of a UInity
@Redmires
I use Windows. XP on the desktop and Windows 7 on the laptop. The only apple in my house is in the fruitbowl ![]()
As mentioned, if someone develops and releases a commercial product then I would be the first one in the queue.
Tog
Because Kinsky can't change the source or volume on Naim devices ![]()
Tog
I am not interested to invent a new upnp control point.
I am interested to control the uniti functions like volume control, radio, input selection, ...
Maybe we can build a plugin, or something like that for kinsky.
Tog
My UQ came with a remote control that does that. I'd sooner there was a Knob on the box so I could just turn that, but the remote control works fine. Perhaps the next iOS app will control the volume too, but until then I'm very happy with the remote.
That said, I'm all for opening up the API so those who want to develop something can - I might even use it if runs on iOS, OS X or Linux (the only windows in my house are in the walls) and is freeware, but I wouldn't pay for it.
