nd5 xs running in
Posted by: rich46 on 25 October 2011
install nd 5 in a few minutes . first hir es album sounds very good cold . let you know how it runs in the next few days.
ps not impressed with app either
Good man - be interested to hear how you get on. The NDX took a couple of weeks to come fully on song.
James
no i cant . using it from digital output. couldnt see the point as i only wanted this.didntwant to pay £3000 .the dig outs are identical . will reply again . at this point feeding it with 24/96k tracks the quality is very good.... ive just download 192k/24 bit tracks and they wipe the floor with what ive hear from ANY cdp ... cheers
'wipe'?
fascinating!
please keep us posted.
Dave
p.s. I think this is the one for me — I'll just wait a few years until it shows up used ![]()
Hi Rich46 -
Digital output into what? What's your setup look like these days?
Hook
I do not think that running in is needed if digital rather than analogue out is being used.
agreed. but the streamer still has components that have allways been cold. run in and paid for ,now its mine regards
Congrats Rich,
Listened to one today, and was Very impressed.
Good luck
Justin
25 yrs old crap 16 ,bit wait to you hear 24bit/ 192kz down load
what does the rest of the system look like?
dacxp+ /psu feeding either mono 300 monos .just about to put valves back in operation during winter iconaudio mb90s/la4
cyrus transport/psu / gyro set up with eurphoric pre amp feed ing quad 2805 0n musical fidelity stella stands
all equipment on hifi racks all 3000 cds ripped with ripnas in flac feeding nds5 streamer/ipad
the naim streamer is very clean at top and bottom end . radio is good too
the quad sound stunningly fast with 2496k downloads from hd tracks
just to say ive tried several streamers, the last one was the cyrus stream x.
the 5 is a great overall package through the ndac. the output through thequad 2805 is simpley the best ive heard. WITH ANY SOURCE including the black stuff..
96k and 192k downloads are just excellent , its just a pity it will take years for all music to be offered.
what did suprise me how good the ns5 sounds via the analogue output is.
there is an improvement when you use to short cat6 cables to connect the nds5 and the ripnas together with a powered network switch, i used a netgear one
did try to add a power supply to the dac but i thought it was too expensive for a small improvement. changing the stardard power supply of ripnas to a regulated linear type improved the performance .
the app is ok but needs work on it radio is fine and the display for radio via ipad is pleasing.
Hi Rich, interesting read thank you. I'm using a Cyrus CD7/psr-x as a transport into the nDac at the moment. How does the ND5xs compare to the Cyrus transport into the nDAC for normal CD quality material, is it any better?
the cyrus cdt+ transport /power supply into the dac is a class act ,fast and clean .
the ns5 is very veryclose and it is difficult to say which gives the best music.
just to say fast access to close to 3000cds with the streamer must have my overall vote
the s treamer from its analogue output is behind the transport/dac, so it should be .
i bet the 5 will out sell all naim streamers it is a great affordable solution for most.
I bought an ND5 XS and picked it up yesterday. All I've done so far is listen to the FM, first rock station I tuned in had PF the wall, WOW!. My iMac is being loaded with my CDs and I don't have the right connector and cable, also since it was mom's computer I have to get a friend to adjust it. It'll be hard wired. Sound is incredible but I had bought the 555PS for my CDX2, I have to leave for 3 days so it'll warm up and maybe next weekend I'll get to use more of the system. I'm not very adept and all this stuff.
