XPS 2 connection to NDX or DAC?
Posted by: ace88 on 25 October 2011
I have the NDX and nDAC and I can only afford to purchase one XPS2 .. Which would you connect the XPS2 to...giving the best results?
Posted on: 25 October 2011 by sbilotta
nDac
Posted on: 25 October 2011 by ace88
Thank you for the replies :-)
Thanks Allen,
Coincidently, I do have a Powerline to spare and will try as you suggest.
Just curious , should I connect the XPS to NDX, Do I still need to turn on the main switch on NDX?
Posted on: 25 October 2011 by Simon-in-Suffolk
Hi, if you use another PS with the NDX it overrides its inbuilt PS and switch completely unlike the NDAC where the off board PS powers only supplies the analogue circuitry leaving the inbuilt PS to separately provide the digital circuitry power.
I agree upping the NDX power lead improves its ability to provide a good clean SPDIF stream. I use a  Belden lead for NDX and NDAC aux, and Powerline for the 555PS.
Simon
Thank you All for the infos. much appreciated . Now I can't wait for my XPS to arrive :-)
Thanks again
