Desktop client 1.6
Posted by: Bluelake on 28 October 2011
I have my Uniti Serve just back from repairs. The software has been updated. Now when I run the desk top client on my pc, I have a message that it's too old and I shoul update.
I running 1,5 SP2 and from the forum I understand there is a 1.6 update...but where can I find it ?
Posted on: 28 October 2011 by sktn77a
http://www.naimaudio.com/userf...6b_server_update.zip
Posted on: 29 October 2011 by Bluelake
In fact my unity serve is already running 1.6b. My problem is withe the windows software Naim Desktop Client. It keeps on saying it should be updated, even after reinstalling it from the link provided...
Posted on: 29 October 2011 by sktn77a
Yes, the firmware version is 1.6b but I believe the Desktop client (v2) is contained in the ISO file that you burn to CD.
Posted on: 29 October 2011 by GerryMcg
That's correct you must install v2 of the DTC when updating the Unitiserve to 1.6.
Gerry
Posted on: 29 October 2011 by Klout10
Please be aware to remove the old version of the DTC before installation....
Michel
Posted on: 30 October 2011 by Bluelake
Ok thanks ! The problem was I didn't uninstall the old vesion. Once uninstalled I could install the new one.
Posted on: 30 October 2011 by Tog
You have to uninstall the old before installing the new version ??!@@@!! Ridiculous. Tog
Posted on: 30 October 2011 by Klout10
I guess you blame Microsoft...
Michel
Yes, I installed the new version on top of the old one. It looked like it worked, but in fact it didn't replace the old on. Uninstalled the old one solved the problem,,,,
I thought I found a solution to manage my music....but in the end I think my turntable is much less trouble than all these updates and software stuff...
Not at all - that would be watching someone eat soup with a fork and blaming the manufacturer of the fork. Naim chose to use a rather daft way of administering the uServe when there are perfectly good alternatives to a windows programme that requires deletion before updating. Tog
Posted on: 31 October 2011 by Klout10
Hi Tog,
Sorry, I'm not that much "into" computer stuff, hence my choice for the HDX ;-)
Michel
Posted on: 31 October 2011 by Tog
Understood :-) Tog
