Uniti and Phono
Posted by: john R1 on 30 October 2011
what would i need to buy to play vinyl through my Uniti
Posted on: 30 October 2011 by naimUnT
Stageline if you want to stick with Naim. It will be powered by Uniti.
Posted on: 01 November 2011 by graham55
You should have posted this in the main HiFi Corner board, then you'd get fuller answers.
My son has a Uniti, and I seem to recall that it has a powered input. If that's correct, it will power a Stageline (as advised above), or (depending upon which TT you're using) you may be able to use the rather superior, but now discontinued, Prefix. The advantage of using either is that you don't have to buy a separate power supply.
Speak to your dealer for proper advice, though.
Posted on: 04 November 2011 by Redmires
I have a Stageline on my Uniti, connecting the LP12. Works perfectly. You will need to specify the type of cartridge, MC or MM, as it comes in different flavours.
