UnitiServe Problems with Mac?
Posted by: heihei on 31 October 2011
Am having real problems with seeing the UnitiServe on my Macbook. Every few days if I go to the UnitiServe via Safari it just hangs there with the Naim disc logo, requiring a reset of the UnitiServe to work correctly.
Ok - this isn't a massive thing, but is rapidly becoming tiresome! Any ideas??
Posted on: 31 October 2011 by Tog
Not particularly Mac friendly - you may need the Windoze only DTC. Tog
Posted on: 31 October 2011 by garyi
Download the latest flash from Adobe.
Posted on: 31 October 2011 by heihei
Nope - that didn't work!
Posted on: 31 October 2011 by PBenny1066
Have you "reserved" an ip address for the Unitiserve on your router, so that Safari is always pointing to the right address ?
Cheers, Paul
