3.1 av receiver
Posted by: Frits Van Der Veer on 18 November 2011
Hi all
I want to have a (very) good 2.0 system for (streaming) audio. So most likely, after a good thought, search and listen,  will choose superunity plus monitor audio 200gx gold ( have a listening session set up)
BUT!
I want also listen to films, SACD etc in 5.1. So I am lacking a 3.1 system. So far I choose the marantz sr for the remaining 3.1 incl decoding the av sounds, leaving 2.0 idle?!
Does anyone know an affordable (1200£ alternative for only 3.1 incl av decoding. For ecstatic and sound reasons it will have to steer the rear and centre of the MA gold series.
I cannot be the first to want a 3.1 system ?!
Thanks!
Frits.
Posted on: 18 November 2011 by Frits Van Der Veer
Ai part of the post did not go through; I am looking for an alternative 3.1 av receiver for ~£1100 to power up the remaining MA speakers. I cannot be the first one to want a 3.1 av receiver?! Any thought or recommendation?
Posted on: 18 November 2011 by BigH47
I had a Arcam system, bought 6 years ago. It provided center and rear(mono), it was such a faff to set up, each disc seemed to need a different  setup, I eventually gave up, as the resulting sound was dissapointing.
Whether a newer set would be any better, but you really need to audition as the sound needs to balance well with your main rig.
Posted on: 18 November 2011 by Guido Fawkes
I have an old Linn Classik Movie System, it is 5.1, but won;t play SACDs. I don't use it at all these days for exactly the same reason as BigH - wires everywhere and getting the .1 right was a chore and .5.
I use Eclipse speakers in my office, I bet these would sound great in a 5.1 system if you could tolerate the wires.  I know Eclipse does a sub, but it may be a silly price. I just use a stereo pair
Posted on: 18 November 2011 by NickSeattle
I tried the Marantz AV7005 for a couple of weeks into NAP 150 and NAP V175.  I decided I was happier overall with my old Denon AVR-4800 into the Naim amps instead.  Lots to like about the Marantz; but the factory remote conflicted with the Naim remote for the NAC 112.  Don't buy unless you listen and like the sound in 5.1 AND 2.0 (and with headphones, too, if you care).  Maybe I got a bad sample, or set it up wrong; I think not.  After two weeks of aggravation, I was relieved to have the old AVR back in place, and budget building toward an nDAC.
I will be interested in following your progress.
Good luck.
Nick
I listen to films in 2 channel. If I were more serious viewer of films maybe a sub for the films with explosions and such like.
Posted on: 19 November 2011 by pjl2
Several years back I had a full Naim surround set up, ie. DVD5/AV2 etc., (but only Naim speakers for front L/R), plus a projector. I had a few years of terrific fun from this but I eventually went back to 2 channel. Reasons: I got fed up with the lounge looking like the auditorium of a cinema rather than a living room. Also the whole thing was a hassle to get balanced right - what seemed a good sound balance for one movie didn't suit another so well. But the predominant reason for returning to 2 channel was simply that the novelty of surround wore off, and once that had happened I found that the experience added very little, if anything, to my enjoyment of movies. I find that watching movies in stereo is absolutely fine. So I would caution - don't spend a fortune on a surround set-up unless you are absolutely sure you need/want/will stick with it. Personally I would just use the Superunity for music and movies and plough the remaining finds into something else.
Peter
Posted on: 20 November 2011 by tonym
I watch lots of movies and a good surround-sound system's essential for me. Expensive and difficult to get right but well worth it - 'ordinary' stereo doesn't cut the mustard for films.
I don't understand folks' comments about sound balance; a sound meter's essential & as long as you set the system up correctly to begin with there's no need to fiddle with it unless you alter something. Film soundtracks vary enormously in terms of sound quality and channel balance but then that's the way they've been mixed.
Posted on: 20 November 2011 by pjl2
Tony,
The balance issues for me were mainly the sub and surround levels. On some 5.1 movies they would seem to contribute nothing at all to the sound, whilst on others they would be clearly active. I appreciate that in theory, once initial set-up has been performed correctly, then further adjustment should not be required. But as you say, DVD's/Blu-rays are all balanced differently, and the sound mix for the home version of the movie will be different from the theatrical mix designed for large auditoriums and (relatively) lower quality sound systems. Taking the variables into account (different disc manufacturers/distributers, different engineers, differing quality and formats of original source material) it would perhaps be surprising if any kind of consistency between discs existed!
As for surround sound itself, there's no doubt at all that it adds another dimension to watching movies, and with a projector this is the nearest you will get to a commercial cinema experience at home. A large-screen TV is a quite different experience and no contest IMO. As I said, my wife and I had terrific fun from our set-up for a few years. I began in the end though to find it a bit "full-on" for regular viewing,  and eventually it was only used about twice a week. The rest of the time we just watched DVD's on our 26" TV with a dedicated 2 - channel system. A totally different experience - far less impressive, and certainly nothing like a commercial cinema,  but somehow just easier to relax into and enjoy the movie. All just my experience/opinion of course!
Peter
Posted on: 20 November 2011 by PJT
Fritz,
Denons work better than most for your budget.  My first venture was the budget 2106, feeding pre-outs to my 282/250/Allaes, and also a pre-out to a NAP140/nCent.  Worked very well, and I am happy that no subwoofer is required either.
Later on I added surround sound using in ceiling speakers (Niles, run off the Denon's amplifiers) - relatively low cost, but definitely gives a far more immersive movie watching experience.
Pete
Posted on: 09 December 2011 by Eloise
A couple of alternatives...
First the Marantz NR1402 (5.1) and NR1602 (7.1 with AirPlay) both have 2.1 outputs for front channels to a HiFi system. The Marantz are great (IMO) with good sound quality and have had most legacy inputs removed allowing for a low profile design.
Second you could add a Naim NAP175 and an Audiolab 8000AP.
Eloise
Posted on: 14 December 2011 by Manu
A Nvi can be found for cheap Must have the latest display upgrade
Posted on: 20 December 2011 by trickydickie
I'll second an NV-I, great value used and works well with the Unity gain inpus. Excellent sound and cosmetic match for other Naim components.  Just make sure it is all working and has the latest firmware, mine was flakey until I loaded the latest.
I bought it to free up space as I had a Yamaha DSP-800 amplifier processor, these are good but getting a bit old now.  I gained 3 shelves as I was able to replace a tuner as well
Richard
Posted on: 09 February 2012 by Fritsveer
Hi Guys
Thanks for the replies (I had some difficulty login on).
I have decided to purchase the superuniti (will come in next week) together with a Monitor audio 300GX. For the rear and centre the 50 and 150GX plus sub.
If have on review a Cambridge audio azur650r as, from reviews, sounds very good!
I will use the CA as receiver and pre-amp for video related sounds. The Superuniti will handle all music related stuff. I will set it up as soon as i have the superuniti.
So far the CA is installed and sounds good!
Sorry for the delay.
Keep you posted if you like!
