NDX 24/192 board update - anyone done it ?
Posted by: james n on 21 November 2011
Just curious if anyone has taken the plunge yet ?
I'm still undecided whether to have it done but at the end of December i'll be out of the free upgrade period. I don't have any 24/192 material, Airplay doesn't interest me and my NDX sounds superb with no stability issues.
With minimal reports on how well the 24/192 boards are working in the new Qute / ND5 players i'm reluctant to rock the boat at the moment given how well everything is working ![]()
James
Do you know if I can get a Qute upgrade to support Airplay?
Guido - From the PS interview at Milan
It's expected that the upgrade price for NaimUniti and UnitiQute will be in the region of £250, and Naim plans to offer both of these systems in either a standard version, or at a premium price with the new board and 24-bit/192kHz capability.
The premium versions will sell for approximately £175 more than the standard ones, making a 24/192 UnitiQute, for example, around £1600.
The new board also adds 802.11n Wi-Fi capability to the systems, in addition to the current b/g (although Naim still says wired networking is preferable in terms of stablity and reliability of signal). The new board also makes them, Stephenson says, 'AirPlay ready - at least in terms of processing power'.
Pressed for clarification, he said he expects products fitted with the new board - and of course the new ND5 XS and SuperUniti - to gain full AirPlay capability during the first quarter of next year, this being implemented via a simple firmware upgrade at that time.
James
Simon
James.
Simon
Hi Simon -
Were you in the operating room for the surgery? Was it done while you waited, or did your dealer have to send the NDX out? Hopefully the new board installation was simple and straight forward.
Very glad to hear your initial impressions of sound quality are positive! I plan to have this upgrade done just as soon as it is available here in the US. Am interested in comparing 24/96 versus 24/192, but more than that, I'd like to be ready for Airplay just as soon as Naim is!
I had set up an ATV for purposes of streaming Spotify and Youtube and other apps from my iPad, but even at 320 kbps, streaming did not sound very good through the ATV, nor was it very reliable. I know from listening to iRadio on the NDX that 320 kbps can sound really good (e.g., Radio Paradise, Linn Jazz, etc.), so am hoping that Airplay from my iPad to the NDX will be a big step up!
Thanks!
Hook
Hi Hook.
Yes I was in the operating room - and I used exactly that term yesterday
. It was all very straighforward.
It took about 15 minutes, but I had already done the firmware update, otherwise that can make the whole procedure last about 30 mins. It was just long enough to have a great cuppa tea and talk about ShoutCast with Andy.
Simon
Had mine "done" so to speak and can't honestly tell any difference in sound quality. nStream app seems to all work a bit quicker and slicker but that may well just be down to the software upgrade that happened at the same time.
If you can get it done for free then why not go for it, nothing to lose and lots to gain (future proofing, no loss of secondhand value compared to un-modified versions, able to use all future features such as Airplay etc.)
Just collected my NDX from my dealer following its return to HQ for the new board. I cannot hear any differences. At this point I doubt that "running in" the new board is going to make much difference to the sound quality on "standard definition". I did download a short piece from Satie on 24/192 which I wanted to use as an introduction to higher resolution music. My router cannot keep up with the demands of 24/192 and cuts out every 5 seconds or so. Might be time to review my internet provision and service provider ! By the way, the Satie sounded good so 24/192 has potential. My biggest worry is that record labels will see 24/192 as another way of selling our music collections to us again but do a hatchet job on the "upgrade".
SinS - can you say a little more about the board change you witnessed, please. How straight forward was it? Thanks!
