ND5XS and Squeezebox
Posted by: pixies on 26 November 2011
I am considering adding an ND5xs to my system (it would replace a squeezebox Transporter). However I use other squeezebox devices around the house. Would this cause any conflict? All my music is stored as FLAC files on a PC and the squeezebox devices link into Logitechs Media Server software which is also on the PC. In other words I would have the ND5XS in my main system but would still want to use my Squeezebox radio in the bedroom and the Duet in the kitchen.
Other option could be to add NDac to the Transporter, but thats another box to find a home for! The ND5XS will integrate well with my 155/Flatcap/152 and keep box count to 4.
I have SB's Touch and Duet on the same network as ND5XS, sharing the same music library and there is no problem at all.
I suppose there could be an issue if one of the devices takes your network close to the limit but there's no issues with this here.
Thanks Chris. Looks like I should have no problems.
If you use a Vortexbox to house your library you can stream to both Squeezebox and UPnP.
Tog
In the pas I have had problems with squeezebox and upnp on the same network, especially with upnp clients. I think it's linked to the broadcast discovery messages.
Some trial and error may be required.
The solution could be if you had issues to create two separate subnets and route between them, but you would need a proper router and some network knowledge to setup so this approach might not be viable.
Simon
The latest version of the SqueezeServer (renamed "Logitech Media Server") is said to work as a UPnP server - plenty of postings on the bulletin boards saying it doesn't work properly. I haven't tried it myself but there seems to be a possibility that it could be used for both SB and Naim media players. I use JRiver and haven't discovered any conflict yet.
I am already using the Logitech Media Server successfully with both Squeezebox players and NDX. The NDX is able able to see and play the playlists created by iPeng. Its great.
ASenna04
Not quite.... The new server software allows the SB devices to be seen as a UPNP Renderer to any UPNP Servers you may have on the network.
It works fine with J River Media Center. It shows up as a DLNA zone.
FYI, local control of the Squeezebox in this scenario is limited to "Pause".
-Patrick
I have been using my Logitech Transporter for the last couple of years with my system, and now usng NDX & Asset UPnP as well with no problems what so ever. All works/sounds great.
Squeezebox Server vers 7.6.2, not the latest I know but it works and I can't be arsed changing just in case I get grief!!
Hi Iver
My recent experience with digital upgrades.
I had a Squeezbox Touch using a Teddy Pardo TTouch PSU with Klaus v3 software mods into a Lavry DA10 DAC. Few months ago I purchased an nDaC, this was a big improvement over the Lavry.
Last Saturday I purchased a mint ex-demo UnitiQute for £995. All I use the UQ for is the digital output as I already have a 152xs/155xs/flatcap.
This raised the bar even further, I was sceptical that 1s and 0s were just 1s and 0s and there’s no difference between streamers, I WAS WRONG
Hope this helps
Sean
purchased from my local naim dealer the audio room
