Best UPnP server
Posted by: Augusto Giusti on 30 November 2011
Dear all
My gear: Unitiqute, mac mini, nDac and ipad2
I'm thinking to leave a blind mac mini running something streaming to the qute.
Twonky, playback or asset??
I just want to have the full cover art resolution on the iPad2. Most of media servers like minidlna downsize the folders.jpg to 160x160. I don't want that
Thanks, Augusto
Posted on: 30 November 2011 by pcstockton
can you run windows on the mini?  if not I am sure Tog will be along soon.  This will entail you dedicating a computer to his idea.  Why not buy a cheap miniPC running XP.  then you can run any number of servers.
Option C - A NAS with a UPNP server running "on it".  Not sure how that works though.
Posted on: 30 November 2011 by james n
No need to complicate things. Playback works perfectly.
James
Posted on: 01 December 2011 by Michel Werner
James pointed Playback to me. It works just fine.
Michel
Posted on: 01 December 2011 by Augusto Giusti
Thanks! With Playback can I get full resolution cover art?
Posted on: 01 December 2011 by james n
Yep
Posted on: 01 December 2011 by Dov
Playback works very nicely. But be carefull with some antivirus/firewall software like VirusBarrier, they interfere with covert art transmission.
Dov
Posted on: 01 December 2011 by Simon-in-Suffolk
Hi, Twonky long in tooth, and has only marginal support for WAV files. Asset running on a tiny WHS box is hard to beat. It also transcodes for specific upnp clients, so supports your mp3 network player in the kitchen as well as your Naim....
Simon
Posted on: 01 December 2011 by MangoMonkey
You might want to try the squeezebox server. Just works on Windows. ND5XS seems to find it just fine.
Thanks a lot
Posted on: 02 December 2011 by pixies
Hi MangoMonkey
Can you clarify the point about using squeezebox server with the ND5xs?  I use squeezebox products around the house and squeezebox server to stream my FLAC files to them. I am just about to demo the ND5xs.  I had assumed that I needed a separate UPnP server i.e. like Asset or Tversity in order to play my music.  Can I just connect to squeezebox server?
Posted on: 02 December 2011 by MangoMonkey
Well, the naim dealer plugged the ns5xs into my network and it automatically found both the squeezeboxserver and a windows media player upnp server. So no setup required, at least for gge demp
OK thanks.  I have collected the ND5XS so will plug it in later today and see how things go.
Posted on: 02 December 2011 by rich46
power it up,auto set up. sell your  cdp
Rich46.
Sold the Naim CDX/XPS last year!  Have embraced streaming ever since and now demoing the ND5XS against my Logitech Transporter.
Posted on: 02 December 2011 by likesmusic
As of release 7 Squeezebox Server has been renamed Logitech Media Server (LMS), and is a decent UPnP server - it will serve pictures and video as well as music if you're that way inclined. Not only that, but a Logitech Touch can now be used as a UPnP renderer, so you could use a Touch for a second or third player if you had an NDX as your main player, and nothing stopping you using other control points like Kinsky either.
Looks like I need to update to latest squeezebox server release!  ND5XS installed and sounding great.  Just have a slight problem with n-stream app which is not finding the player.  I guess I should start a new post for this problem?
