Any chance of getting spotify on NDX/ND5XS?
Posted by: MangoMonkey on 01 December 2011
Still need to use my squeezebox touch. If ND5XS gets spotify, I'll ditch the touch in a heartbeat.
Keith
I don't think airplay is going to be quite enough. Ideally, I would like to be able to use my ipad (that I'm using for other tasks) to control spotify, and for the data to get streamed to the airplay device.
Don't want to keep my ipad connected to the device.
Looks like what you would have to do is the following:
a) Have spotify installed on a computer.
b) Use Ipad app to control spotify on that computer. (computer needs to be running all the time, or be able to wake up when i use the ipad app).
c) Route stream from computer to the airplay system.
I'll stick to squeezebox for now. Simpler to stream it from the sb into a dac. In end effect, it's like getting an ipod and hooking it up to a dac.
Keith
I use SB as well. But I think 2 developments would be a huge improvement:-
1. Embed Spotify in the upnp server. Spotify has been releasing API's for different systems and this should be quite simple to do.
2. Naim to embed Spotify in their network streamers (although this seems unlikely to happen, but I might be surprised).
ASenna04
Once again the replies all imply that a customer is happy to pay out for Apple products.
Any chance of getting spotify on the HDX??
Michel
