'Client Adaptation' in Twonky Server - No Naim Options
Posted by: spacehopper on 10 December 2011
Hi
Since joing the forum a few weeks ago, I have now picked up my ND5 XS which, as my first Naim source, has really impressed me! Previously I was using a Rega DAC with vortexbox which was a hard act to follow, but now it's got to be Naim ![]()
Setting up the UPnP had been a challenge, though I have settled on Twonky Server on QNAP, which seems a popular choice from reading other forums.
Anyway I have noticed within the Twonky configuration (on pc until my QNAP arrives) a page dedicated to 'Media Recievers', which lists the IP addresses of the various devices presumably showing to the server. Of course one of these is the ND5 and alongside it is a pull down menu of maybe 100 different UPnP devices which, if selected, allows some kind of 'Client Adaptation' to occur.
Can anybody explain what exactly this might involve and what the benfits might be if any?
Unfortunately there are no Naim options (at this stage!) within the list, but I have found that if you select 'Bubble DS Control Point' you get high resolution album art within n-steam, whereas if you allow Twonky to select 'Generic' you get a very low res, blurry image.
Cheers.
