CD fungus
Posted by: EJS on 14 December 2011
Scary... found a CD in my shelf collection, which shows the early signs of a fungal infection. Looks like condensation or clouding on the inside, around the rim. You can clearly see the strains coming in from the side of the disc. Hope this is the result of faulty manufacturing?
FWIW, it's an EMI CD from the mid 90s. So far, other discs are unaffected. It was kept in the original jewel case, on an open shelf but not directly exposed to sunlight...
As it's the only one, I re-ordered it new, via an Amazon seller (it's out of print).
Had it happened to one CD only so far.
Also called "CD rot".
If use the search function, there were several threads on this, I seem to remember one of the producers/distributers were replacing "rotting" CDs.
Hmmm this is different than CD rot (the brown-coloured bronzing rot that affected some early discs) - my disc shows a white substance along the rim of the metal, beneath the lacquer.
Do they still play? If so CD-R them soonest.
Rot/fungus and bronzing are slightly different beasts:
http://en.wikipedia.org/wiki/Disc_rot
http://en.wikipedia.org/wiki/CD_bronzing
The disc I have that got rot became completely unplayable.
The entire surface was affected, a "swirling" pattern all over the disc.
I had that with a Sex Pistols CD. I tried polishing it with something slightly abrasive (I can't remember what it was but it was meant for cars) which did the trick enough to rip it.
I guess there may be two types of rot/fungus, which both are material aging:
- oxidizing of metallic reflective layer (rot stopping it from being as reflective as intended)
- aging of outer plastic layer (rot of plastic layer stopping it from being transparent for the laser)
It ripped OK, the contamination has not yet reached the data layer. When the replacement arrives, I'll dump the disc and its packaging. So far I haven't been able to find it on other discs, and I've checked a fair few.
Oh the joys of CD's that were supposed to last a lifetime. When they're b'gger'd they don't play, gone forever. A bit of fungus and it's RIP, pardon the pun. I bought a vinyl LP today from a charity shop. It had been stored in a damp place and was affected with lots of spots of fungus. One clean on my KM RCM and I now have an excellent Blue Note album I had been looking for.
Lesson: vinyl was around for many decades before CD's, will be around for many more after CD's are gone, and sound better.![]()
+1
Ho hum. We'll just have to disagree on all that won't we. I've never had to return a cd 20 times because it was so noisy.
Nearly 2000 cds, some more than 24 years old and not a single problem.
Here we go again........
CD rot has nothing on the smell of a musty album cover. On the other hand, my cassettes haven't developed any odour over the years.![]()
The one LP I had that was affected by fungus was theoretically playable, but far too noisy to be pleasurable. On the other hand, I have had CDs since the first year of release and not one has become unplayable or in any way less than flawless (not the recording - the CD itself). Admittedly I did have one that wasn't playable due to milky plastic, but that was from new. I just took it back.
It took 2 mins to rip and about 10 mins to burn a CD-R recorded at 4x, on MBP / iTunes, which sounds indistinguishable from the original. In theory, as long as a CD can be copied this way, no big harm done... It would be comforting to know that CDs indeed would last a lifetime, but alas once you've spotted a black swan there's no going back.
