HDX problem
Posted by: Hutton1969 on 03 January 2012
Hutton
Hi Hutton!
This has happened to me a number of times too.
I´ve had my HDX-SSD for over a year now and have ripped over a
1000 cd´s.
Try ripping another cd and it will work.
There are some cd´s that my HDX doesn´t like and it just won´t rip.
And no, they are not SACD or any other format, just plain cd´s.
I don´t know why?
So far 12 cd´s out a 1000.
Strange...
I have also experienced the cd drawer getting stuck ie not opening.
Try powering down front switch and wait 30 sec after it´s powered down,
then switch off back and wait 1 minute.
Switch on the back and wait for it to power up.
Now go to the front panel meny and press System Setup, then
press Rip or Play Mode, now select OK to play CD.
Press open drawer then close.
Now do the same procedure and select Set To Rip CDs.
Sometimes when I´ve switched from "rip mode" to "play cd" mode and then back it has
worked.
I hope this helps as I know it´s frustrating
Michel
Thanks Sonic and Klout. Have tried pretty much all possible solutions to no avail. Will contact dealer for replacement CD drive.
Yes the Internet connection is ok. I suspect that the failure of the drive door to open plus the refusal to recognise a CD means a mechanical fault.
Hutton,
Sorry to hear of these problems. I have had the same in the past but usually a full power down for a few minutes and re-boot solves the issue. I hope it's sorted quickly.
Please keep us updated.
Jason
Have tried re-booting several times but to no avail. The dealer has confirmed the CD drive must be replaced which hopefully they can do in store. I am just waiting for confirmation that they have received the part.
Hutton
