Every Picture Tells A Story LP Sound Quality
Posted by: HiFiKid on 13 January 2012
All
Just dug out my copy of every picture tells a story by Rod Stewart. (Not played for Ages) The sound quality I am getting from it is abissma.  It sounds all muffled and lost.  The condition is good and lovely and clean and shiny.
Was the original recording really that bad? Got 5 stars on Amazon
Played on an LP12 and other lp's sound ok
Does anybody else have a copy the same.
Thanks HiFiKid
Posted on: 13 January 2012 by Gale 401
I have a mint original copy or two.
Dont play them much though.
Will dig one out for a listen later.
Stu.
Posted on: 13 January 2012 by osprey
I just played my copy (Netherlands print 6336 548) on WTA and it sounded OK (similar than some other records played recently) and certainly not muffled though the sound quality as awhole can not described to be great compared to best ones.
If you can get a hold on a second copy you might want to give it another try. The music itself was better than I remembered.
Posted on: 14 January 2012 by Wugged Woy
In my opinion, EPTAS is possibly the very best rock album ever produced.
When I consider his more recent stuff, it makes me  think what on earth happened........ Respect of course if you like the recent stuff
Posted on: 15 January 2012 by HiFiKid
All
I think I have found the problem.  Ref thread now on HiFi corner I seem to have a tweeter not working in one of my SBL speakers.  It seems more noticable on this lp and even less so when I play a cd.
I found it because i noticed the voices were now always one sided which was never the case.
Big bill comeing I think.
thanks all
HiFiKid
