Naim DAC advice for Mac / Supernait
Posted by: novak on 16 January 2012
I have a Supernait/Hicap and some Harbeth C7s, and my Mac Mini is my source, using the optical out. It's the latest mini on the market, so apparently low jitter. Overall the system sounds good, even with Mp3, but anyone serious about hifi would say I'm not getting the most out of it, and that's because of my source.
Using my Mac Mini, I normally play Spotify 320kbs, but sometimes play FLAC files using Songbird, but my library is not anywhere near that of my Spotify account. I realise FLAC is better but I can't move away from Spotify completely. I plan to build the FLAC collection however.
I have been told that a Naim DAC would be most suitable (Instead of a streamer), and I can play via my Mac Mini still.
My questions are:
- Does the NDAC play FLAC files that are stored on the Mini? If so, how? Do you need the Naim app to select them?
- Is the NDAC much better than the SN DAC?
- Is the NDAC even the right solution? Should I opt for something else?
Thanks!
