New 3.13 software update for Naim streaming products
Posted by: Steven Hopkins on 18 January 2012
Software Version 3.13 for Naim's streaming products is now available for customers to download from the Naim website. This new software update enables some performance enhancements for the NDX, NaimUniti and UnitiQute and an alarm clock feature for the NaimUniti and UnitiQute only. The software release follows the launch of the ND5 XS and SuperUniti in the summer.
While the update brings the software of the NDX, NaimUniti and UnitiQute into line with the ND5 XS and SuperUniti, please note that the software update will not enable 24bit/192kHz streaming and ALAC (Apple Lossless) compatibility, which the ND5 XS and SuperUniti have offered since their launch. 24bit/192kHz functionality and ALAC compatibility can be added to NDX, NaimUniti and UnitiQute units already in the field, however this requires a hardware update that can only be carried out by Naim qualified technicians. Please contact your Naim retailer for more information on the pricing and availability of the 24bit/192kHz update.
The new 24bit/192kHz streaming board has been in production for the NDX since November 2011. Customers have been able to specify the NaimUniti and UnitiQute with either 24bit/192kHz capability (at a charge) or standard 24bit/96kHz capability since November 2011. Updates to existing units are chargeable, however NDX units shipped on or after 1st July are eligible for a free update until 29th February 2012.
To download software Version 3.13 along with some simple instructions on how to administer it to your Naim streaming product follow the link below.
A note to NaimUniti owners wishing to install Version 3.13
Please note that NaimUniti units running software version BC SW 10198 should NOT have this update installed. Please contact support@naimaudio.com for further information. This only applies to NaimUniti running BC SW 10198. Version 3.13 is fine to install on all other NaimUniti units and on all UnitiQute and NDX units.
Users can check the software their unit is running by following the below procedure.
From the Front panel:
Press and hold ‘list’ button.
Using the button ‘prev’ scroll down to ‘Factory settings’
Press ‘Stop’ button (this is the OK button) - This takes you to ‘system status’
Press ‘stop’ button again – This takes you to the ‘System Status’ list
Use ‘prev’ to scroll down and you will come across BC SW at the bottom of the list.
Press and hold ‘List’ to exit.
