Controlling of Uniti
Posted by: Woj on 20 January 2012
I am considering Uniti for some time but I am bit confused regarding how it can be controlled. I understand that there is an iphone application ‘nstream’ which should give me the best option to control the Uniti without need to use the remote controller. Unfortunately I do not have iphone or any other apple products. But I have an Android phone. I read on this forum that I can use several upnp ‘control points’ to control Uniti. And here is my question to these who use such option. Will such android control point give me a full access to Uniti? Will I be able to change the volume for example, change the inputs or it is just for controlling the streaming side of it?
I have Synology NAS and it has got Audio Station build in which I find quite good (I use it to stream music to my phone). Is that Audio Station compatible with Uniti? I had some time ago Unitiqute at home for tests but it did not work with Synology Audio Station. The audio station did not see Unitiqute as a ‘media renderer’. This was some time ago and the Unitiqute had one of the early firmware (but it worked with nstream). Has anything changed? I would be grateful for any advice. I really fancy Naim equipment but would like not to sacrifice on the control side. I am using Transporter now which is soooo easy to control using basically any type of operating system.
