LP Storage Cubes
Posted by: Analogue Rules OK on 25 January 2012
Excellent value if you buy 3
http://www.argos.co.uk/static/...rtNumber/7191101.htm
Chris N
Posted on: 26 January 2012 by Andy1912
If you need something with a touch more capacity you can always get one of these - I bought one the other week, I suspect capacity is about 3000 LPs or more perhaps (£80).
Posted on: 26 January 2012 by Kevin-W
Where did you get it from Andy? Is it Argos as well?
K
Sorry no it's Ikea: http://www.ikea.com/gb/en/catalog/products/80071319/
ATB
Andy
Posted on: 27 January 2012 by Gale 401
Andy,
They hold just over 1,000 LPs.Stu.
Posted on: 27 January 2012 by Analogue Rules OK
The convienience of the cubes are that they can be placed almost anyware without dominating the room, also they can be moved quite easily with the LPs in situe + they hold approx 75LPs andcost only about £8.50 each.
Chris N
