Live F1 2012. Whole season Sky only?
Posted by: Tony Lockhart on 29 January 2012
I'd have thought there'd have been an on-line service for those in my position where the Sky satellite is the other side of some very tall trees (thankfully) and Virgin's cable service still hasn't made its way into the protected hamlet of Commercial End.
Tony
Tony,
The answer is yes their is away.
It will still cost you a few hundred squid though.
You will need a 80cm dish a box and the right sports card.
Have you got a good Sat shop any where near you?
Stru.
I like trees more than Murdoch. TonyTony,
South face dish on the Hotbird sat.
Those trees will be no problem with a 80cm dish at ground level.
Astra will also be ok.
You can flick between both if you use a motor.
You can control both from the box and its remote from your arm chair.
I use a Humax HD box with two card slots.
Also with a 80cm dish when it rains hard you dont loose signal.
You also dont need any planning permission.
Anything over 80 ?you do.
Have a look round some sat and av forums.
PS,
If you are going to the next NPS meet with Tonym and the Guy's?
Have a chat with John/fixedwheel,He knows a bit about this stuff.
Stu.
You can borrow my chainsaw Tony, I'll dig it out for you (the blood'll soon wash off).
Tony
You will probably be able to connect to sites showing F1 through the myp2p website. I watch football and occasionally cycling though this site, the picture quality is often poor, but I'd expect F1 to be very good.
I wouldn't recommend you use a computer that is used to access your bank or email accounts, the risk of picking up a virus or trojan is quite high. I have an old computer that is used solely to watch sport on the internet, the odd virus or trojan isn't a problem.
