What brands remote codes doesn't collide with Naim?
Posted by: Somchie on 05 February 2012
My Marantz NR1402 remote collides with the Naim remote codes.
For example, when turning up the volume on my Marantz with the Marantz remote even the volume on my Nac 282 goes up.
Pretty annoying.
I have connected the Marantz to the Nac 282 with Unitigain.
Can you guys confirm any other brand that doesn't have the same remote codes as Naim?
Posted on: 05 February 2012 by Richard Dane
Somchie,
that's interesting.  Naim and Marantz both use Philips RC5 (as do many, many others).  There are different codes for 2 channel volume and AV volume.  Interesting that Marantz are using the 2 channel code for AV.  It may be that you can change the code set on the Marantz remote.  You should be able to do this with most AV gear to avoid any conflicts with 2 channel kit.  I'd check it out.
Posted on: 07 February 2012 by JamieL_v2
My old Sky+ (standard definition - set to control a Sony Trinitiron as well) used to change the input select on my Nait3 amp.
I complained to Sky, but they, not surprisingly, has not heard of Naim.
Annoying when a £200 basic receiver interferes with a quality amp.
The HD Sky+ Pace box seems OK, I haven't changed any settings to match my monitor, but would rather not risk it.
Posted on: 08 February 2012 by pixies
My BT vision remote seems to mess with my system.  It seems to freeze up my amp when used! Very annoying.
Posted on: 08 February 2012 by NickSeattle
Marantz AV7005 volume also turned the knob on my NAC 112.  Very annoying.  Returned the Marantz.
Nick
Posted on: 09 February 2012 by Somchie
Nick
Hmmm... I had a AV7005 a earlier combined with a Nac 200, but I can't remember how that worked.
Anyways.... I replaced the NR1402 with a Yamaha RX-A810 and it works just fine.
Posted on: 12 February 2012 by Ubaniigama
Hi Richard, Somchie,
Please let me know if you find a solution.
My Marantz AV7005 and NAC282 controllers clash.
U
Posted on: 18 February 2012 by Ubaniigama
Richard Dane - any feedback?
U
Posted on: 20 February 2012 by Richard Dane
U
I'm afraid I can't help here - I don't use an AV7005 so can't try it out.  However, I have flagged this for Naim tech support input.  Have you contacted Naim's customer support for help yet?
Posted on: 20 February 2012 by Somchie
U
I think it is safe to say that all Marantz AV-amps will collide with Naim. With "all" I mean current line-up. So far I have tried, NR1402, AV7005 and SR7005.
My "solution" was to switch to Yamaha
