How the switching power in the NAS affects the sound quality
Posted by: bb7668 on 05 March 2012
After spending more than a week in:-
- setting up the NAS (the latest Synology 712+);
- copying the music files into the NAS while preserving iTune file structure;
- hunting for the cat. 7 lan cables;
- extracting the embedded album art from the 15,000 plus aiff formatted songs so that the album cover could properly displayed in the iPad; and
- trying out and comparing the different iPad remote software (e.g. n-Stream, Plug Player and DS Audio),
I finally managed to get the Naim ND5 XS up and running and the music files could now be streamed from the NAS to the player without a hitch.
However, the excitement was rather short lived. Whilst the instrumental presentation was analytical enough, I found the vocal part was a hint harsh and aggressive. May be I was exaggerating, it sounded as if the singer's throat was a little bit too dry and there were very slight rough edges at times.
Some members in other forums commented that the main culprit is the stock 12v 6A switching transformer that used to power up the NAS. This appeared to be some sense in this proposition as the NAS was essentially functioning as a CD transport to transfer the data. Accordingly, the quality of the power supply of the NAS does play an important role in the overall scheme of things. To tackle this problem, someone actually tried to use an Energizer 18000 Battery Power Pack (18000mah!) to power the NAS and claimed to achieve good result. Personally, I would not go as far as that but I was currently very tempted to buy a linear transformer for the NAS.
Here, I would like to check if any member has found the sound of the Naim ND5 XP a little bit harsh/hard when the data (music file) is streamed from the NAS. Specifically, has any member actually replaced the stock switching transformer provided by Synology with a better substitute?
Many thanks in advance!!
P.S. Alternatively, I am thinking if the harshness or aggressiveness is caused by the cat. 7 lan cable. I will try to experiment with cat.6 lan cable later on.
