NVi and Remote not speaking to each other...
Posted by: RobinS on 15 March 2012
I've had the problem many times of the remote not working, usually fixed by doing a reset as advised in the FAQs.  This time I've done a remote reset, and then reset both the remote and NVi but with no effect.  The message on the NVi screen says that the AV system code has been reset but although most of the remote buttons seem to work, the up/down and left/right arrows do not work.  They have the effect of  changing the input (disc, digital, analogue etc) or mode (auto, mono, stereo etc).  Not a lot of use when you are trying to work your way through DVD menus!  I've even tried powering off the NVi and changing the batteries on the remote.
Anything else I could try?  All suggestions very welcome
Robin
Posted on: 16 March 2012 by Mike1380
Your remote is in AV mode - hence trying to control the large chunk of AV2 residing in your n-Vi.
Press the DVD button, it'll then start trying to control the large chunk of DVD5 residing in your n-Vi.
HTH
M
Posted on: 16 March 2012 by RobinS
Thats brilliant thanks Mike - too blindingly obvious!
Robin
