N-Stream Ipad App IP Config
Posted by: Superturismo on 20 March 2012
Hi,
New to Naim and the forum can anyone tell me how i configure a manual IP address on the N Stream App on the I Pad.
Everytime i open the app it crashes the first time. Second time lucky it opens but cannot find my NDS-XS Streamer. Switching the Auto Detect to off it simply displays a data cell containing the word IP addresss. However I cannot edit this cell and enter my units IP address.
Can anyone help, i'm extremely frustrated?
Posted on: 20 March 2012 by RaceTripper
First question (thing to check) is, are your iPad and ND5 connected on the same local network? Your iPad must be connected to local WiFi and not using 3G for networking.
Posted on: 20 March 2012 by Superturismo
Thanks for such a prompt response. The NDS is hard wired to the router and theiPad is on the samewirelessnetworks. Should I move the NDS over to wireless. I simple can't edit the settings in the app at all. Any help would be most appreciated.
Thankyou
No, they just need to be on the same local network. My ND5 XS is on ethernet and I have an iPad on WiFi. It connected just fine. Try rebooting both devices. Also make sure your router isn't doing MAC address filtering, unless you're sure both devices are registered.
Still no joy! I can't get the app to find the streamer and when I disable auto find the setup page won't let me edit anything as the screen is locked.
Hmmm...make sure the ND5 isn't in the setup menus. I know that while the n-Stream app is connected, it behaves differently if that's the case.
Posted on: 22 March 2012 by kiba
I'm running N-Stream/IPad for Unitiserver. From time to time My app crash on opening. Then I have to reeboot the Uniserver (switch on/off). Done some set-up experiements on the N-stream, but nothing seems to help
Posted on: 22 March 2012 by Steven Hopkins
Run up n-Stream…
…wait for n-Stream to not find a device…
…so hit “Setup” …
…and switch “Auto Connection” off…
…tap in the “IP Address” box…
…and enter the IP address of the NDX / ND5XS / Uniti / UnitiQute / SuperUniti.
Sorry n- server, but still the same, and i have auto connection off. From time to time every second day it crashes, and i have to reeboot unitiserver
