Audirvana
Posted by: Chris_C on 21 March 2012
Anyone have experience of the Audirvana player for OSX? I am trialing the PLUS Trial version at the moment and I am so far very impressed. It provides iTunes integration with the ability to play native FLAC/WAV/AIFF files etc, and all beautifully packaged.
c.
Yes it is another good player that produces a perfect bitstream like iTunes and Decibel and others, but has the advantage of being FLAC friendly and having a nice user interface that you may prefer.
My philosophy is that the SQ from any bit perfect Mac player produces the same output, so use the one you feel you like the best. They do have to be set-up for bit perfect replay though for this to be true. Moreover, if you prefer a player that is not 100% (iTunes with some EQ) then no reason not to use it in my view.
Yes Chris that is my view.
If you turn off the EQ and max out the volume and set the sample rate in Audio Midi correctly for the track you are playing then iTunes will output exactly the same bitstream as Audirvana - at least it did when I tested it by capturing the bitstream through a UQ in to a Yamaha CD-R. I tried this with several players and they all produced the same results. I cannot hear a difference between any of the bit perfect players on a Mac through my system - either through the UQ or the Naim DAC.
However, some folk report they can hear a difference and so I'd always say try it yourself and go with the player you prefer.
In test (bit captures and my own listening) I cannot tell between different players on a Mac or WAV, FLAC, ALAC or AIFF. Every time I've captured a bitstream they were the same. Ripping CDs with a Naim US, iTunes, XLD made no difference either (there are cases when dBPowerAmp can do a better job - HDCDs).
Getting iTunes right is a bit of pain so I use an add-on called BitPerfect which does this, but using Audirvana will work just as well and it will play FLAC.
If I change the hardware then I can hear differences - jitter or some other noise (not sure).
All the best, Guy
As Guido says, worth trying a few, Certainly when i was using a Mac and Dac solution (Mac Mini with Weiss DAC2 then DAC202) the differences between iTunes, Pure Music and Amarra were quite clear. All 3 players were outputting bit perfect files (as verified using the Weiss test files and the transparency checker in the DAC202). I've never been able to find a satisfactory explanation to why these do sound different.
James
I recently joint the world of Mac Mini / NDAC and went trough different players... including iTunes/Bitperfect, Fidelia and Audirvana. In my experience the SQ of Audirvana is much better then the other two. I think the reason for that is complete bypass of the volume control software. I think the software/digital volume control resamples/recalculates the bits... and degrades the SQ. When you lower your volume digitally, it "digitally" computes new amplitudes, and these amplitudes are re-done lowering the bit rate. By design the audio is no longer bit perfect when digital volume control is applied.
