NDX vs Mac mini vs AppleTV
Posted by: Zinger on 23 March 2012
1. NDX
2. Mac mini
3. Apple TV
As source, assuming:
- NDX is a 5 out of 5 (i.e. the best in this comparison)
- Apple TV is a 1 out of 5
- all routed to an nDAC with XPS
- all using non hi-Rez audio files of comparable quality
what would Mac mini be? I understand this isn't a fair comparison. I'm just looking to gauge where Mac mini falls into this picture ... I have Apple TV, and have auditioned NDX (not at home). Now I am wondering where the Mac mini sits in this stack given NDX is a bit further down in my upgrade path for various reasons. What kinda SQ differences I will be looking at etc
With a decent optical connection to the nDAC they are all 5 . . .
Try a proper blind test with the volume matched very accurately.
IT
I have tried the following
Apple TV into Naim DAC
NDX into Naim DAC
The difference is not small to me.
Remember that the ATV will resample everything to 48khz.
James
If your were to assign a score to:
1. NDX
2. Mac mini
3. Apple TV
Mac Mini by a country mile - have you ever tried to edit a spreadsheet on an NDX or Apple TV.
Oh I see what you mean Mac Mini + Naim DAC/555PS by a country mile then
Mind you what about the NDS
AS James explains Apple TV does funny up-sampling (how many 44.1 in 48?) - I have one, I tried it with my Naim DAC, it sounds ... well odd. It is fine with YouTube though.
NDX + Naim DAC/555PS by a country mile as well.
I can't speak for Mac mini, but Applle TV converts everything ( unless you jail break) to 48kHz sample rate, which is not ideal. For compressed files it's ok, but for non compressed lossy files its quite lacking compared to NDX into an NDAC. I currently use both into my NDAC, and I regret to say the AppleTV is highly lacking compared to NDX in creating convinvincing audio replay into the NDAC. I use my AppleTv for films and home movies only now..
Simon
Guido, can you be more clear? How much better the ndx is compared to a new mac mini, when they both are linked digitally to ndac? Music wise...
I have not heard them side by side, but have heard the NDX many times and think that it does an excellent job streaming in to the Naim DAC/555PS. I have a Mac Mini and it also does a fine job.
The Mac Mini has direct access to a hard disk, where as the NDX needs to get the music from a NAS. So they are different.
Which is better? You really need to audition to decide which is better for you. I think adding the DAC/555PS to the NDX makes a big difference.
I chose the Mac Mini because functionally it suited me better; I think the NDS (as demo'd by Naim) was a step-up so I'm prepared to sacrifice some functionality to accommodate the NDS (once it has settled down: I'm not keen on testing it, I'll let other do that who enjoy that sort of thing). As I understand it I can run Asset on my Mac Mini without any need to pay a penny to Microsoft - so I can stream to the NDS from it. As I could also use its optical out too then I don't have to sacrifice much.
If hi-res is unimportant then the W4S Sonos ZP90/Naim DAC/555PS is a superb player too.
The key is the Naim DAC/555PS, which I think is a significant step up from any other Naim digital player I have heard. NDS excepted. As long as you use a decent quality transport to feed the Naim DAC/555PS then you'll enjoy superb SQ. The NDS is the only integrated player I have heard that I thought was even better (I've not heard a Linn KDS, but the NDS as long as it is glitch free will be all I ever need).
As always I can't tell somebody else what they will think sounds best. There are some well regarded non-Naim DACs that I was taken to task over, simply because I said I didn't think much of them. I still don't and wouldn't want those products, but others like them.
My choice was Mac Mini/Wireworld Supernova 6 optical cable/Naim DAC/555PS and still would be unless you can stretch to the NDS.
I use a QNAP NAS, Mac Mini (iTunes + Amarra Mini) and USB M2Tech Young DAC for now. I'm happy although I'm curious to hear the NDS+XPS v's HiFace Evo, NDac+555PS......
In my view you don't need the M2Tech stuff if you are using a Naim DAC with a new Mac Mini - just go optical between the two with Wireworld Supernova 6. I say this because it will give lower jitter bitstream and eliminate RFI noise. The beauty of the Mac Mini is you can avoid USB altogether.
However with older Macs, MBPs and PCs - the jitter from an optical out even if it has one is not always great and so a device like the M2Tech hiFace can be advantageous. The MacBook Air disappointedly doesn't have an optical out.
So it is really a suggestion for the new Mac Mini only.
Then hiFace is good choice if you want to go for a Naim DAC.
If you are M2Tech fan then I definitely suggest trying the standard hiFace before plumping for the Evo ... or if you can try a Halide Bridge.
Mind you you have a well regarded DAC, which must be fairly new so perhaps just stay with that until everything settles down. Products seem to be coming and going at fair rate at the moment ![]()
If its just feeding data into the ndac with low jitter, it's hard to improve, unless you want to spend thousands more, and have a much more complex system, too.
I used to use Airport Express and also apple TV but they were awful. They sounded cloudy and flat, not to mention the annoying clocking problems when partnered with the supernait. Hope that helps.
Omg, that can not be so difficult, assume that's just me......
Now the macmini is set up.
Connected a optical toslink cable.
How do I connect a toslink to macmini?
Have to use the 3,5 mm to toslink adapter and then in the headphone output?
Thanks again.
Christian
Sorry false topic.
