HDX problem 2911from desktop client
Posted by: Hpw20001 on 31 March 2012
I am geting fault message 2911 on the loopback adress 127.0.0.1 when i try to acess HDX with desktop client, at the same time i get internal disk busy on the display. This goes on forever
Front panel on HDX does not update information of whats been playing, desktop client does.
If I take out cat cable and do power of and rebot everything works normal with remote but when i connect cat front display stops update information.
HDX and display gets IP and responds on ping. I use dynamik IP adress. Any ideas to find how to solve the problem would be helpfull.
Peter
Peter
