Distortion when using ipad3
Posted by: David S Patterson on 01 April 2012
Some help and advice appreciated.
Bought iPad 3 yesterday and have downloaded a trial album, at wav to it. connected to my Dac and whether playing direct from pad or streaming via homeshare I have distortion and dropout on left channel.But if I use headphones from the iPad there is no issue.Using an iPod touch to the Dac shows no problems.Have used different leads to eliminate that that variable.Am thinking there is a fault with my new pad.Any help or things to try.
Posted on: 01 April 2012 by David S Patterson
Power amp problem, no issues with iPad.
