Superuniti quickie
Posted by: PeterX on 27 April 2012
Does the superuniti have have a unity gain input? Thinking of getting one but it needs to take an input from my nVi.
Peter
Posted on: 27 April 2012 by naimUnT
Peter X: Short answer is yes! You can use an external preamp for sure. I'm using one with my SU at the moment.
Posted on: 27 April 2012 by PeterX
Thanks for that. Which input do you use as I couldn't see one for unity gain on the on line manual.
I'm considering changing my supernait so I have streaming options.
Peter
Posted on: 27 April 2012 by Frank Abela
You can use any input. Any analogue input can be assigned to fixed volume on the SuperUniti. As per the manual:
4.3.8 Rear Panel Analogue Inputs
Parameter Options
Enabled:
Yes / No
Name:
User definable
Input Trim:
±10dB
AV Fixed Volume:
Yes / No If No is selected the input will behave normally. If Yes is selected the input will operate at a fixed volume and the SuperUniti volume control will be disabled. This enables SuperUniti to be used in multi-channel AV systems with volume control handled by the AV processor. Take care when selecting AV Fixed Volume.
Yes, I had to look it up...
Frank.
All opinions are my own and do not reflect the opinion of any organisations I work for, except where this is stated explicitly.
Brilliant  - thanks Frank.
Does HDX - nDac -SuperUnity together with my old and loved SBLs (and nVi) seem like a good system? I'm awaiting my dealer to get the kit together for an audition.
Peter
Hi Peter,
Certainly does. The SuperUniti is a rather cracking piece of equipment to use as a hub, and it has more than enough power to drive your SBLs.
Frank.
Posted on: 27 April 2012 by MangoMonkey
But what about Mojo? Does it have any Mojo?
What is mojo?
Posted on: 27 April 2012 by osprey
In general "Mojo is a magical charm bag used in hoodoo, which has transmuted into a slang word for self-confidence, self-esteem or sex appeal." But in this context?? Maybe an electrical equipment can be described by that term, don't know.
Posted on: 27 April 2012 by joerand
Jim Morrison had mojo.
In this case it applies to how the music plays, not the electrical components.
Posted on: 28 April 2012 by aht
In NaimWorld, Mojo=PRAT, I believe.
Posted on: 28 April 2012 by Julian H
I found the SU has loads of mojo when streaming. When using it as an amp, with separate source, was a bit jinxed.
