What's the problem with UnitiQute?
Posted by: IR on 16 December 2010
I use the UnitiQute and get a message.
it show on the UnitiQute.
Fault 10
Radioscape HPI Comms
What's the mean?
I can use it now.
Pleas help me.
Posted on: 16 December 2010 by Guido Fawkes
Somebody more knowledgeable will be along soon, but I think it is an error on your DAB radio chip - if you have switched it off, waited a while, and the switched it back on and the error persists then you need to contact your dealer or Naim.
There may be a reset sequence to solve this, but it needs somebody from Naim to comment. You could e-mail support@naimaudio.com
Posted on: 16 December 2010 by Develyn
Try contacting the Naim dealer that sold it to you.
Posted on: 16 December 2010 by IR
I already e-mail support@naimaudio.com.
Hope they can help me.
But..., someone can tell me, how to reset the UnitiQute?
I can't find it out.
Posted on: 17 December 2010 by Peter_RN
Hello IR and welcome.
You can switch the unit off leave it a minute or two and switch back on, this should clear any minor issues.
Or you can enter the Factory Settings Menu (press the spanner symbol on remote) and navigate to the Factory Settings Menu (4.10) and reset ALL settings for a full reset.
If you have not yet found it, there is a Reference Manual that you can download from the Naim website here.Manual Download.
This is a fuller version of the one packed with the Qute. Look for the ALL-IN-ONE Player dropdown and select the manual you need.
Good luck, hope you are sorted soon.
Peter
Posted on: 17 December 2010 by IR
Hello Peter_RN
Thank your reply.
But…, the LCD(screen) it always show on
Fault 10
however, I do, it always show on like that.
Is't have any possibility?
Hello IR
I'm sorry, did not realised the screen was showing this message permanently.
I don't think there is anything you will be able to do without support from Naim or your dealer, Most likely Naim I would think.
Hopefully, technical support will respond to your email shortly. Sorry cannot help further.
Peter
Posted on: 20 December 2010 by IR
Hello Peter and thanks.
One day I wake up, the UnitiQute is working,
I don't understand but it working now.
I'm lucky?
I want to thanks everyone help me.
