Wireless bridge to NAS and then wired to NDX/UnitiQute
Posted by: meaculpa on 29 December 2010
Having now played with Ethernet Audio in the shape of a Sonos ZP90 through my N-vi/NAP200/MA RS8's, I am looking to take it a step further with a Naim source.
Before I get to the conundrum of what next in the audio hardware (Expensive - NDX/nDAc/202 or less expensive N-vi/UnitiQute/NAP 200 - Thanks to Allen B et al for the reply to an earlier post), I am thinking about the much discussed issue of wired v wireless.
Now, my scientific brain tells me that as long as the bits and bytes are there, then audio performance should be OK, however my experience with my ears over the past 20 years with "real hi-fi" tell me that components and electronics can make a huge difference.
I currently use dbPoweramp (in my view absolutely great) to rip CD's on my Mac running Parralel, and then transfer this (and downloads) to my NAS through a wired Netgear switch which in turn uses my Apple Time Capsule to wirelessly stream to the Sonos/N-vi in the sitting room.
In wanting to keep the dbPoweramp/Mac/Time Capsule in the study, I was wondering if it would be OK to take the NAS into the sitting room and hard wire it to a wireless bridge and my new Naim streamer so that it was "hard wired" and then transfer the additional files as I get them wirelessly to NAS.
I think from a computing point of view this would work, (as I already have about of TB of WAV's on the NAS and any additions now should be relatively small, however would passing the wired connection from the NAS to the Naim streamer through the internals of the wireless bridge be just as bad sonically as my current wireless set up straight to the streamer?
My normal route would be to demo this with my ears, but before I go and buy the bridge, I just wanted to know if I was getting too hung up on wireless v hard wired?
Andrew
Posted on: 29 December 2010 by Harry
This is pretty much what I have set up. There is a wireless bridge in the lounge cupboard which talks to the hub in my office. The NAS and HDX are wired to it. The sound quality/musical enjoyment/whatever you want to call it of playback through the wired system has got me up to a level I wouldn't have believed possible a year ago - although a nDAC also contributes. Streaming wirelessly from the NAS to my office presents no problems. I haven't tried it the other way round.
The sheer convenience and ease of using the system (via an iPad in my case) has added hugely to the enjoyment but sound quality is my primary consideration. I would also mention that most of my music has been ripped on the HDX and that which hasn't (mostly 25bit) is fed to the HDX or DAC on a USB stick, not streamed across wirelessly to the lounge,
For 25bit read 24bit
Posted on: 02 January 2011 by meaculpa
Harry,
Thank you for your post.
I have now tried this with my Sonos and an Airport Extreme in bridge mode, and it works fine, as with your system.
I would have liked to have used an Airport Express, but this only had one ethernet port.
Also OK to rip from dbPoweramp wirelessly to the NAS now in sitting room.
Now I have wired connectivity, It looks like a NDX and a 202 pre amp to drive my NAP 200 and the n-vi (when the display is fixed!)handling the AV.
Then, just need the unitiQute for the study, but my other half is already giving me disparaging looks!
Andrew
