Av2 problem - Help !
Posted by: Sam Campbell on 22 December 2010
Hi, I just purchased a 2nd hand AV2 and NAP175.The nap 175 works fine (tested with my 102) but the AV2 powers up to standby (lights on right hand of the display). Within 5-10sec of switching the unit on, it goes back to standby...
Also the remote doesn't work (not sure if this is related)
Im going to take it into the naim dealer here, but wondering if what people thoughts are on this..
btw: i have got the unit to hard-reset, makes no difference.
Posted on: 22 December 2010 by Dungassin
Try resetting the remote :
https://forums.naimaudio.com/ev...07&s=67019385&cdra=Y
Posted on: 22 December 2010 by Sam Campbell
already done this.. no luck.
Posted on: 22 December 2010 by Manu
It May be a good idea to ask your dealer to reinstall firmwares.
