Spotify replay
Posted by: Steve2 on 15 January 2011
I used to listen to Spotify regularly and as a consequence went onto buy CDs that ordinarily I would never have come across. Recently I came back to it but find that instead of just playing the tracks it stops after one track and you have to select another which is mildly irritating to say the least.
Is this because I have not upgraded to Premium or that I need to alter my computer settings. I have an Apple. Any advice much appreciated.
Cheers SteveT
Posted on: 15 January 2011 by Bob McC
I'm on old free subscription and it doesn't stop between tracks for me.
Posted on: 16 January 2011 by David Scott
It only does this if you play a track from the search results. If you click on the artist's name in the search result list, the page that takes you to will play through an album without stopping.
Posted on: 16 January 2011 by Steve2
Thanks for the advice David, much appreciated. Unfortunately it still does not play continuously for me even after following your advice. Not sure what I have done or not done.
Cheers SteveT
Posted on: 16 January 2011 by fasterbyelan
Cheers SteveT
Once you have your search result, click on the album you require, not a song from the album. This should then take you to the album itself with the tracks listed. Then simply click on
PLAY and the album will play in the order as per the track list.
Works for me and, yes, I did have the same problem as you when a novice Spotifier!
Karl
Bliss...all is as it should be.....
Cheers Fasterbyelan
SteveT
Cheers Fasterbyelan
SteveT
My pleasure - enjoy
Karl
Must not have explained it clearly enough, sorry. Clicking on the artist's name in the search results brings up a list of all their albums (plus compilations they're on etc.) which play through the same way as if you clicked on the album name as you're now doing. At least it does on all our computers (Macs and PC's) - I just checked it now.
Anyway, Karl's way is just as good.
