Bob Dylan: Mono Vinyl ... Ouch!
Posted by: Hot Rats on 06 December 2010
In stock at Amazon for £240 and at Spin CDs for £189.
I'd like it but at that price I'm going to pass
Posted on: 07 December 2010 by ChrisG
This looks like a "bargain",I wonder if they have stock?
http://www.whatrecords.co.uk/vinyl.asp
How much more of my money do I have to give to Mr Zimmerman!
Chris
Posted on: 07 December 2010 by graham55
Sony have misjudged the price, and I'll be checking again in six months' time, as dealers look to dispose of unsold stock. If anyone spots this happening earlier, a post here would be most welcome!
The equivalent CDs are impressive, though, and nicely packaged.
Posted on: 08 December 2010 by BigH47
Now that is urine extraction, eh?
Posted on: 08 December 2010 by ChrisG
Just checked "what Records: in stock at £149 plus £8 p&p
Not quite so painful.
How many versions of "Blonde on Blonde: do I need....answer, as many as I can get!
Chris
Posted on: 08 December 2010 by glevethan
Order from Amazon US. I was able to preorder at $132. I believe it is now around $170.
In a similar fashion many Stateside have ordered the Stones box set from Amazon Germany as it is less expensive.
Gregg
Posted on: 23 December 2010 by count.d
I received mine yesterday and what a wonderful set it is. Perfectly pressed with no vinyl noise.
All the lps sound better than the Sundazed mono equivalents. They're more open, Dylan sounds more lifelike and generally more engaging. They all sound great.
It's an expensive box, but well worth it if you like Dylan.
Posted on: 24 December 2010 by glevethan
I have been listening to my set during the past week. This should be a mandatory purchase for everyone. The music is absolutely fundamental and groundbreaking. The quality of the box set sets a new standard. A true labor of love.
HIGHLY recommended.
Gregg
Posted on: 24 December 2010 by kennth
i also got mine this week , sound quality is top notch, again no surface noise
Posted on: 24 December 2010 by fathings cat
Where is the cheapest place to purchase the box set, really hard to resist......
Posted on: 31 December 2010 by count.d
whatrecords does it for £150 + post. (there's only a US pressing of it, so you're ok)
Posted on: 31 December 2010 by Aleg
jpc.de Bob Dylan Mono on Vinyl for €190 [around £163 , depending on exchange rate] + €6 p&p (fixed rate). Comes from within EU so no additional VAT or import duties.
aleg
Posted on: 18 January 2011 by Jay Coleman
Agree with Greg. Mandatory. Not to expensive from Amazon.
Listening now. The pressings are superb and the music very important especially when you consider it was all done before 1966 when old Bob was only 25.
Posted on: 19 January 2011 by mudwolf
uh oh, don't tempt me.  I happened upon his first 2 LPs in a box given to me. The early stuff is important but I'll have to go back and listen to see if I want it.  I have the reissue of BonB.
Bobby was young just like the Stones and all the others.  Then a hard fast life took over.
Posted on: 23 January 2011 by fathings cat
Not wishing to compare the two formants what are is the cd box set like - anyone purchased wish to comment?
Gary
Posted on: 25 January 2011 by glevethan
I do not have the CD's however many postings on the Steve Hoffman forums indicate they are also spectacular
Gregg
Posted on: 26 January 2011 by ChrisG
Hi
The record label "Music on Vinyl" based I think in the Netherlands are pressing their own versions of the new mono remasters. The lacquers have been sent over from the US and are cut and pressed in Europe. They are available singly from Amazon , so if you want to cherry pick one or two, not a bad idea. When you search say for "Blonde On Blonde" on Amazon be sure to check that it's the "MOV"edition there are many.
Chris
Posted on: 28 January 2011 by matt podniesinski
Gregg and Jay,
I have most of the original Columbia mono Dylan LPs in fairly good shape. Have you done any comparisons?
Matt
Posted on: 28 January 2011 by Jay Coleman
I have one -- The Times They are a Changin'. Gregg and I did a very quick comparison. The new ones are very close. They probably have more bass. I would say, though, if you have clean originals, there is no need to buy the box. Indeed, the original had something going for it over the box.
Gregg?
