Can I control 282 volume with Sky HD remote? YES YOU CAN!!!
Posted by: dazjones on 12 January 2011
Hi everyone,
My universal remote has just packed up and before buying a new one, I was just wondering if there is a Sky HD remote (rev8) code for controlling Naim pre-amp volume?
Many thanks guys & girls,
Daz
Posted on: 18 January 2011 by Trevor
No dont think so.
I got a really nice One for All Digital 5 remote for about £20. You can program it with codes from existing remotes for up to 5 different items as well as entering the normal codes for items.
Posted on: 19 January 2011 by dazjones
Hi everyone!
Thanks for your reply Trevor, but last night I figured it out! As lots of Naim owners have Sky and I'm sure lots pump their TV through their amps, I was determined to try and sort it!
Here we go:
This works for the latest rev.8 Sky HD remote.
Press TV
Press and Hold ZERO + SELECT until you get 2 blinks of the LED
Key 1 2 1 7 (philips/panasonic codes) then you should be rewarded with 2 blinks.
The UP/DOWN Select arrows should now control the amp volume.
To "push through" the Naim volume to the +vol- buttons Press and hold 1 + SELECT until you get 2 blinks of the LED (2 + SELECT reverses this).
Now press the Sky button and the Naim volume should be controlled by the volume buttons.
I noticed the 0 (ZERO) key had a little speaker on it and thought I would experiment........ Hours later, sorted!
Daz
https://forums.naimaudio.com/di...ent/2833539973551957
