a connection problem
Posted by: neil w on 25 April 2003
my set up
yamaha a2 av amp fronts fed into52 via unity gain
the a2 has a ext ernal decoder facility whereas you hook up ext dec and all you use on the a2 are the remaining 3 power amps
the a2 ext decconnections are single phonos for center /rear right/rear left
how can i connect an av2 to this
thanks neil
Posted on: 26 April 2003 by NB
Try e-mailing Naim directly on this one. These should be able to help you.
NB
Posted on: 26 April 2003 by Geoff P
Neil
If you also go to the NAIM official website where you can download the user manual for the AV2.
In there is info on how multichannel in and out is handled.
What you also might then have to do is fork out for some special RCA to DIN cables which can be ordered from Chord, at a price!
regards GEOFFP
