Uniti Foobar and UpNp -fast forward ?
Posted by: phk on 28 August 2010
Hello
First I am glad that "bubbleguuum" is a member of this forum. I want to thank you and congrulate you for the developpement of the foo-upnp component which is really great.
It works well with my Uniti, but it is not perfet yet. Indeed, as has been said, the "pause" does not work. Also, the fast forward or fast-rewind (inside a track) from the remote controle from the Uniti do not work either. Is it possible to fix this ?
Thanks again.
Posted on: 28 August 2010 by 0rangutan
FF and RW also do not work with most UPNP servers, not just Foo. Likely the same issue/bug as pause problem. Fingers crossed for 3.0.0.
Posted on: 29 August 2010 by bubbleguuum
Originally posted by phk:
Hello
Thanks again.
The last version of the plugin v0.99.29 should support pause. You'll have to enable the new option "Allow clients to pause stream indefinitely" found in File>Preferences>Tools>UPnP>Server>Content
Posted on: 30 August 2010 by phk
Thanks for your answer. I had already installed v0.99.29. But the pause still does not work : I can only stop a track and play it back again from the beginning. Could I have made something wrong ?
