Stylus cleaners
Posted by: Mekon on 22 April 2003
I've just had a new cart fitted (DV 10X5), and want to keep it clean, but don't fancy shelling out £70 on Epay for an AT-637. I've seen mention of the Lyra liquid & brush, and some green Linn material. My dealer recommended the Russ Andrews product.
Other than the AT-637, are they all much of a muchness, or is there a particularly good one? Are there any to avoid, and are there any that aren't suitable for the Dynavector?
Posted on: 22 April 2003 by David Stewart
What you really need is a soft bristle brush for routine removal of surface dust and lint etc., plus a short stiff bristle brush for removal of the more stubborn caked-on detritus which accumulates over time.
A small soft artists paintbrush is ideal for the former task. For the latter I find the Disc Doctor product very effective. It can be used dry or with the supplied fluid. Available
here and elsewhere.
"Opinions are like belly-buttons, everybody's got one" Posted on: 22 April 2003 by David Stewart
Interesting - it appears from the photo that the AC014 brush is the same as the one supplied with the Disc Doctor product!
Posted on: 22 April 2003 by Frank Abela
Lyra's SPT is the best! Gets rid of gunk and is OK with Dynavectors. The brush it comes with is also excellent.
Frank.
All opinions are my own and do not reflect the opinion of any organisations I work for, except where this is stated explicitly.
Posted on: 24 April 2003 by Raphael
Hi there
I use an Onzow Zerodust and it works really well - no problem with Dynavectors. Just in case you have not heard of it, it is some slightly sticky stuff into which you lower your cartridge/stylus and then lift up. The sticky stuff holds the dirt and leaves you with a clean stylus. You can clean the sticky stuff under running water.
Available from hififorsale.com - I am not connected to them!
Raphael
Posted on: 24 April 2003 by Simon Matthews
Artie
Have you recovered from the Spinal Tap tour?
Posted on: 25 April 2003 by domfjbrown
Originally posted by Raphael:
Hi there
Second that - works nice on my NAD533 (in a bedroom system).
I also use that Discwasher brush/fluid set (cost about a tenner in 1999) on my P3 in the main rig - I usually use it fluidless. Works possibly better than the Onzo stuff, but it's way more scary to use and the cartridge is more vunerable.
When the music's over turn out the lights
