DVD Drive on my Mini has disappeared
Posted by: winkyincanada on 19 April 2010
I put in a CD to rip and the drive just disappeared from the Disc Utility. The disc is stuck in there. Re-booting did nothing.
Any ideas? A trip to the store?
Posted on: 19 April 2010 by garyi
Hold down the left hand mouse button whilst starting it up.
Otherwise there should be a little pin hole on one side of the slot, cannot remember which.
Some copy protected DVDs can really f* a mac up, however the holding in mouse button thing usually works.
If not, then yes the dvd drive has gone south.
Posted on: 21 April 2010 by winkyincanada
It eventually (overnight) recovered and actually finished the rip. All is well again. The drive is back. It was a japanese import disc and may well have been a bit odd. I have subsequently ripped a few discs with no problems.
