DVD-A Rip
Posted by: P.Bonte on 15 December 2010
Hi,
Can someone help me - if at all possible - to rip DVD-A disks. I realised I have some and would like to extract the (I hope) Hires audio on it. I have no DVD-A player, only a Mac and a PC.
Thanks,
Philippe
Posted on: 15 December 2010 by Aleg
Google for software by "castudio".
Posted on: 15 December 2010 by P.Bonte
Thanks Aleg,
Had a look and seems exactly what I need. Will try out this weekend on a "Automatic for the people" DVD-A
Posted on: 15 December 2010 by Hot Rats
You need a program called DVD Audio Explorer. I have ripped all of my DVD-A discs using this freeware application.
Please post on the board if you need any more help with it.
Posted on: 15 December 2010 by BigH47
DJ is that PC only, it's not clear.
Posted on: 15 December 2010 by AMA
Doctor Jazz -- any progress with Paul Hynes PS on Evo?
Posted on: 16 December 2010 by Hot Rats
DVD Audio Explorer is PC only
AMA ... I have the power supply on order from Paul Hynes. It is due to ship to me on 22nd January 2011.
Posted on: 16 December 2010 by AMA
oooops... That long?
Paul builds to order, hence the delay.
Posted on: 16 December 2010 by 2roomsor1
What about SACD, is there a way to get the stereo tracks off?
There is no known way to rip SACDs digitally. I believe that the Oppo DVD player can be modified to digitally output from SACD but that is not likely to be an option that you want to take.
There are SACD rips to be found although these are done by recording from the analog output of a good quality soundcard. A standard DVD-ROM drive can read from DVD-A discs but now from SACD. The only analog out recoded SACD rips that I have heard have been a couple of the Bob Dylan hybrid discs and a couple of the Rolling Stones hybrids. They sound pretty good.
Posted on: 16 December 2010 by Guido Fawkes
Or by sending PCM through HDMI and splitting out the audio signal - the Cambridge Audio universal player can do this without modification - you do need a splitter box though.
