Photo printer
Posted by: Sloop John B on 18 November 2010
Mrs Sloop would like a dedicated photo printer.
She wants relatively simple, straight from camera to printer for 5 x 7 prints.
Ideally giving very good quality prints.
All help apprecited
All help apprecited
Posted on: 18 November 2010 by Derek Wright
it is cheaper to get them printed at an online place eg
www.Photobox.co.uk
no ink cartridges to dry out, no paper to only partially use, and the ability to choose the size of prints you want for a project or album.
www.Photobox.co.uk
Posted on: 18 November 2010 by Sloop John B
www.Photobox.co.uk
but she wants a printer...............
SJB
Posted on: 18 November 2010 by JamieWednesday
Hi Sloop, don't know if this helps but my wife was the same a couple of years back and I got her a little HP which she loved to use but IMO was sh*t in terms of quality at least partly because of lack of control. However, using the proper canon printer via PC scared her for some reason...
I recently got one of the brand new Canon all in one jobbies, printer, scanner, copier which also allows you to connect camera or card direct (or you can use wifi) and control it from little pop up screen and soft touch buttons on top. So it's replaced the old printer, the scanner and her HP box and I think it's great. Needless to say, quality is excellent.
Posted on: 20 November 2010 by Sloop John B
Thanks Jamie,
We already have a laser 3 in one at home so I don't want to go that route thanks.
Just like your wife mine doesn't want to go near the PC to print.
SJB
SJB
Posted on: 20 November 2010 by A_Bull
Hi,
Try the Canon Selphy range. I have the ES1 (old model). It produces excellent results , although at 22p per pic it is not cheap.
It uses a dye sublimation process which produces instantly dry photos and is generally a lot cleaner than the normal inkjet technology.
There seems to be plenty of new models around currently , which is always a good sign.
Hope this helps
Hope this helps
Posted on: 20 November 2010 by BigH47
If you have a half decent A-I-One, is too much to expect the SWMBO to insert the memory card from the camera into the printer?
Thanks Dave that looks just the sort of printer I think is needed.
Howard, the current printer does not have that option, its more of an office behemoth.
SJB
SJB
Posted on: 01 January 2011 by Sloop John B
Well I ended up getting
a Cannon Selphy
and Mrs Sloop was delighted.
I have to admit the quality of the printed pictures is top class, easily as good if not better than some of the commercial options available.
SJB
a Cannon Selphy
SJB
