Ripping using MAX vs XLD in AIFF
Posted by: MontyMusic on 27 December 2010
All,
Does anyone know why MAX rips at a higher bit rate for AIFF than XLD?
MAX does it at 2116KPS and XLD at 1411.
Anyone know why?
I can't find an answer on the MAX forum
Posted on: 27 December 2010 by nap-ster
Might be worth checking in your Max Preferences > Formats > Encoder Settings that you have 16 bit selected?
Posted on: 27 December 2010 by MontyMusic
Thanks !
24 bit was selected so I've changed it to 16
I guess there will be no sound quality diff as CD's are 16bit anyway.....
