No sound on DVI
Posted by: Polarbear on 09 September 2006
I have a HDMI cable fitted between tv and DVD5 using the DVI connected but can I get picture and sound?
I can get picture but no sound, I have gone through everything on the menu if the DVD5 and DVI set up seems ok but still no sound!
any idea's?
PB
any idea's?
PB
Posted on: 09 September 2006 by Jay
Yeah. DVI doesn't output sound.
Posted on: 09 September 2006 by Polarbear
I was led to believe it did, ok if the dvi doesn't include sound what other cable do I need?
Pb
Pb
Posted on: 09 September 2006 by karyboue
Pb
It depends on what you connect it to for outputing sound.
If it is to an AV2 (or any HT preamp) you need a coaxial or optical cable.
If it is to a HiFi préamp you need a standard interconnect or a Naim interconnect to a Naim preamp.
If you want to connect it to your TV, what is your TV ? Because I don't see how you could input sound in your TV on an HDMI input as that kind of input usually doesn't come with separate sound input
Do you have a DVI or VGA input on your TV ? Because DVI or VGA input always have 2 RCA stereo sound inputs. (VGA is definitly much better than YUV, the separate syncs bring a lot to the image).
Posted on: 10 September 2006 by AV@naim
Karyboue:- did you get my mail?
are you trying to put progressive signal into interlaced tv input?
Av
Av
Posted on: 10 September 2006 by Polarbear
I am using the DVD5 with my sony tv, I have no intention of going down the av route just yet,
regards
PB
regards
PB
Posted on: 10 September 2006 by karyboue
regards
PB
So you have to choose between :
DVI > DVI or 5BNC > VGA or 3BNC (YUV) > YUV, it depends on the input types available on your TV)
+ add stereo sound with a 2xRCA > 2xRCA cable.
Posted on: 11 September 2006 by JonR
PB,
DVI and HDMI connections are different, but compatible, the difference is that DVI is for picture only, whereas HDMI, which I believe stands for High-Definition Multimedia Interface, does picture and sound, as the name suggests.
The DVD5 is equipped with a DVI output only, so even if you have an HDMI cable plugged into it, you will still get no sound. If your TV has a standard pair of L/R RCA inputs, then you will need a separate stereo interconnect cable for the sound.
Posted on: 11 September 2006 by Polarbear
quote:If your TV has a standard pair of L/R RCA inputs, then you will need a separate stereo interconnect cable for the sound.
Thats what I am going to try next, thanks for the advice, anyone got a spare rca-rca cable, Andy C cough
Posted on: 15 September 2006 by Polarbear
Still using the scart, but one thing that does anoy me, through the scart I have the tv sound level on 95 and I can still hardlly hear it.
Is there any way of increasing soun outpput levels?
PB
PB
Posted on: 18 September 2006 by Former member
what scart lead have you?munch
you would have to get a bigger thing to sit on ;;;;;. regards munchquote:Originally posted by Polarbear:
regards
PB
