HELP! The Refurb Blues!
Posted by: Gerard on 18 June 2003
I should probably wait a week or two before I post this but I’m in “panic mode” and need a bit of chat to cope. A bit of history first. In “95-96” I upgraded my 32.5/HiCap/ (2) 140’s to a used 52/52PS and demo 250. The 52/52PS was an early vintage and because it was used it went to Naim for a “refub.” Since the 250 was 1-2 years old it was not sent to Naim. The improvements made from this upgrade were huge as to be expected. The added bass from the 250 required a speaker readjustment but not too much as I recall.
I just received them both back from a “refurb” and now I am having significant changes that I cannot get under control. Two things I noticed right away. Playing either LP’s or CD’s is fine till one or two things take place. If I adjust the volume past a certain volume level, 10-11 o’clock on the dial, things start to unravel, especially if the music becomes dynamic or complex, but especially loud dynamic swings. The soundstage collapses to the center and the upper frequencies become very harsh and congested. Now I did not have this problem before and I am at a loss as to what/why it’s happening, The second problem is that the bass is now really boomy, and overpowering. I expected an increase in bass but nothing like this.
Nothing in the system changed before or after the gear went in for service. In fact, after the gear came back I had a chance to use it for a bit before I had to send he NAC 52 back again cause the remote vol/bal was not working. I did not spend to much time with it but I do not remember it doing what it is doing now.
I massive sinus infection that still has not left my ears 100% is playing some part in the mid-low bass problem but I do not think it has much affect on the first problem.
I have changed speaker placement, VTA changes, cable inspections, etc. The cartridge is only 2 yrs. Old so it should be fine.
I know Naim had to replace the entire front end, logic boards (?) that are related to the display and remote with a later version. Amazingly, and by accident, this change cleared up a right channel ground hum from the tonearm/cart. that seemed incurable. It also reduced overall noise from the inputs in general.
It’s the harsh sounding, collapsing soundstage, dynamic unraveling that really has me worried. I cannot figure out why is happening. ANY IDEAS?
Thanks.
Posted on: 18 June 2003 by Ron Toolsie
Are you sure you have the speaker cables in the 250 connected in phase.. they are after all mirror images (+--+). Try reversing one of them and see if this helps.
Ron
Dum spiro audio
Dum audio vivo
Posted on: 18 June 2003 by HTK
What Ron said.
I've been living with a refurb Hi Cap for 3 weeks on a CD5 and for what ir's worth the characteristics you describe sound familiar, although not as extreme. Things are a lot smoother and more detailed now and I think there's more good stuff to come.
I hope it settles down. I'd put money on you being a very happy bunny this time next month.
Harry
Posted on: 20 June 2003 by Gerard
Mark-
The first liste was 1-2 days post 52 return. The 250 and 52PS were on five days prior. The second listen was 1 week post return. I realize that these pieces need a few weeks to burn-in but this was so different from the first 52/52PS refurb that I was really taken off guard. I was hoping that it was a burn-in issue but after one week of no improvement I kind of got PANIKY! With all the problems I have had in the past 3 years I have become somewhat paranoid.
I sent, Naim N.A.'s Chris West, a note prior to all this regarding the bass increase and some related questions about the repairs, but he did not really mention anything about it needing a "big" burn-in, as it seems it needs!
When I asked him about the front end rebuild and its affect on the 52's performance I was given the impression that it was not going to be much more than what I had already noticed regarding the input noise levels dropping a bit.
It seems that it is alot more than that.
Ron-
The first thing I did was check my polarities of the speaker terminals. My terminals are color coded so it makes it a quick check.
Last night I did a little more listening and found things to have opened up quite a bit. I was able to turn up the vol. a bit more without suffering sound degredation. So, I hope this is a sign of things to come. It's been 9 years since may last refurb so it's almost like buying new and strating over. How soon I forget.
Posted on: 20 June 2003 by prowla
My system (CDX/82/2xHiCap/250) takes about a week to warm up.
Posted on: 20 June 2003 by onlythat
I am having just about precisely the same problem after my refurb of my 72 pre. Things at times are sounding almost broken-- thin and sterile-- and this is with a CDS2 and an olive 250 and a hicap.
Go figure.
