Help with CD5 please
Posted by: monkfish on 04 April 2004
Hi
My CD5 has developed a problem, CD's will play from the start and also play right through but when you select a track (other than track one)the number of the track is displayed but it will not play.
I have tried powering the CD5 down in the hope of re-setting it, but no joy. Any ideas anyone?.
Jim
Posted on: 04 April 2004 by Geoff P
This is probably a dumb comment but are you pressing the "play" button on the player or remote control after you have selected the track.
regards
GEOFF
Posted on: 04 April 2004 by monkfish
Hi Geoff
The player will not play a selected track via remote control or by manually pressing play.
Jim
Posted on: 04 April 2004 by Boekster
Sounds like your dealer has some work to do then! This doesn't sound proper at all. Perhaps ask your dealer tomorwo if he know what's wrong with the player.
Cheers!
Kevin
Posted on: 04 April 2004 by garyi
Sounds like a knackered puck.
Once the puck starts going it can sometimes really fight to do anything other than start.
Hi Garyi
I checked the puck as well and it seems ok.
Jim
Posted on: 07 April 2004 by monkfish
Hi
Problem now solved, it was caused by a mixture of puck slip, new dvd writer and recording at high speed.
Thanks for the replies.
Jim
